EDIT: Sorry about the font/formatting, no idea what's going on there!
PCLINE P03GWKT09 / 093a:262a Pixart Imaging, Inc.
The camera works fine plugged directly into my Manjaro laptop and opens in VLC. Plugged into my RPi Zero 2 however, it is detected but doesn't work.
ipadress/webcam/?action=stream and ipadress/webcam/?action=snapshot both give the webpage starting "The webcam server is currently not running".
Changed various options in octopi.txt camera_usb_options. The camera doesn't support -f and fails with and without -y. I have tried -r VGA and -r 640x480 (this is the cameras only resolution).
pi@octopi:~ $ lsusb
Bus 001 Device 003: ID 093a:262a Pixart Imaging, Inc.
Bus 001 Device 002: ID 1a40:0101 Terminus Technology Inc. Hub
pi@octopi:~ $
pi@octopi:~ $ v4l2-ctl --list-formats-ext
ioctl: VIDIOC_ENUM_FMT
Type: Video Capture
[0]: 'PJPG' (GSPCA PJPG, compressed)
pi@octopi:~ $
pi@octopi:~ $ v4l2-ctl --all
Driver Info:
Driver name : gspca_pac7302
Card type : USB Camera (093a:262a)
Bus info : usb-3f980000.usb-1.4
Driver version : 5.10.63
Capabilities : 0x85200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x05200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (gspca_pac7302: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'PJPG' (GSPCA PJPG)
Field : None
Bytes per Line : 640
Size Image : 115790
Colorspace : JPEG
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Streaming Parameters Video Capture:
Frames per second: invalid (0/0)
Read buffers : 2
User Controls
brightness 0x00980900 (int) : min=0 max=32 step=1 default=16 value=16 flags=slider
contrast 0x00980901 (int) : min=0 max=255 step=1 default=127 value=127 flags=slider
saturation 0x00980902 (int) : min=0 max=255 step=1 default=127 value=127 flags=slider
red_balance 0x0098090e (int) : min=0 max=200 step=1 default=100 value=100 flags=slider
blue_balance 0x0098090f (int) : min=0 max=200 step=1 default=100 value=100 flags=slider
exposure 0x00980911 (int) : min=0 max=1023 step=1 default=66 value=66 flags=inactive
gain_automatic 0x00980912 (bool) : default=1 value=1 flags=update
gain 0x00980913 (int) : min=0 max=62 step=1 default=15 value=15 flags=inactive
horizontal_flip 0x00980914 (bool) : default=0 value=0
vertical_flip 0x00980915 (bool) : default=0 value=0
white_balance_temperature 0x0098091a (int) : min=0 max=255 step=1 default=55 value=55
sharpness 0x0098091b (int) : min=0 max=15 step=1 default=8 value=8 flags=slider
pi@octopi:~ $
pi@octopi:~ ps -ax|grep mjpg 10876 pts/0 S+ 0:00 grep --color=auto mjpg pi@octopi:~
pi@octopi:~ ps -ax|grep webcam 11890 pts/0 S+ 0:00 grep --color=auto webcam pi@octopi:~
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: usb
usb options: -r 640x480
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Jan 5 13:37:27 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -d /dev/video0
i: Frames Per Second.: -1
i: Format............: JPEG
i: Could not obtain the requested pixelformat: MJPG , driver gave us: RGB3
... will try to handle this by checking against supported formats.
... Falling back to RGB24 mode (consider using -fourcc RGB24 option). Note that this requires much more CPU power
Unable to map buffer: Invalid argument
i: init_VideoIn failed
Goodbye...
camera: usb
usb options: -r 640x480 -y
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Jan 5 13:50:42 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -y -d /dev/video0
i: Format............: YUYV
i: JPEG Quality......: 80
i: Could not obtain the requested pixelformat: YUYV , driver gave us: RGB3
Goodbye...
camera: usb
usb options: -r VGA -f 1 -y
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Jan 6 10:26:59 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r VGA -f 1 -y -d /dev/video0
i: Frames Per Second.: 1
Setting FPS on the capture device is not supported, fallback to software framedropping
: Invalid argument
i: Frame period time ......: 1000 ms
Goodbye...
camera: usb
usb options: -r VGA
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
<13>Jan 6 11:01:00 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r VGA -d /dev/video0
Goodbye...
camera: usb
usb options: -y
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
<13>Jan 6 12:36:43 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -y -d /dev/video0
Goodbye...
Freshly installed stable version using the Raspberry Pi Imager tool yesterday, OctoPrint 1.7.2, Python 3.7.3, OctoPi 0.18.0
I have also ran sudo apt-get update --fix-missing and sudo apt-get upgrade, rebooted and no change.
My experience with Linux in general is not great so please go easy on me.
