Camera model: Logitech Stream cam
I am attempting to set up octopi with obico for the first time, Both currently work and allow me to remotely control the printer. My webcam however worked briefly but now refuses to work whatsoever.
I have verified that the webcam works by plugging it into my laptop. After entering the lsusb command I have also verified that a Logitech device is connected. I have done some other basic trouble shooting like moving it to a different USB port and double-checking the config file was correct.
https://all3dp.com/2/octoprint-webcam-setup-camera/ I used this guide to attempt to set it u
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 1920x1080 -f 60
raspi options: -fps 10
http options: -w ./www
Explicitly USB device:
Found video devices:
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video10
/root/bin/webcamd: line 184: printf: 0x: invalid hex number
<13>Jan 9 16:58:55 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www -i input_uvc.so -r 1920x1080 -f 60 -d /dev/video10
i: Using V4L2 device.: /dev/video10
i: Desired Resolution: 1920 x 1080
i: Frames Per Second.: 60
i: Format............: JPEG
Error opening device /dev/video10: video capture not supported.
i: init_VideoIn failed
Goodbye...
I am using a raspberry pi 4b rev 1.2 with 4gb ram. Octoprint ver 1.8.6 and octopi ver 0.18.0. As mentioned before I also have obico installed not sure if that changes anything.
