Can't install any plugins on OctoPrint (Windows installation)
When I try to install any plugin, i get the same error:
Installing plugin "Exclude Region" from https://github.com/bradcfisher/OctoPrint-ExcludeRegionPlugin/archive/master.zip...
c:\octoprint\venv\scripts\python.exe -m pip --disable-pip-version-check install 'file:///c:/users/ofispc~1/appdata/local/temp/tmpetq4ai/octoprint-excluderegionplugin-master.zip' --no-cache-dir
ERROR: Invalid requirement: "'file:///c:/users/ofispc~1/appdata/local/temp/tmpetq4ai/octoprint-excluderegionplugin-master.zip'"
Error!
Could not parse output from pip, see plugin_pluginmanager_console.log for generated output
Tried to upgrade pip, no luck
Complete Logs
https://wtools.io/paste-code/b1Xz. octoprint log
https://wtools.io/paste-code/b1X0 - plugin manager
octoprint on windows 10
You may have a look on this thread:
Okay, so I should just wait for the next release?
Any idea how often they are launching new releases?
You could run the maintenance branch from the OctoPrint repo (where it is patched), by checking out & installing the git repo. - but be warned, whilst it is maintained very stable, bugs & regressions can sneak in.
You can also install plugins manually from an external url, by activating the virtual environment then running the command that is listed on the plugin repository.
1.4.1/2 were released at the start of August, after 1.4.0 in March, but it would be down to @foosel as to when 1.5.0 would be released.
Hi... I'm "they"
Hi Gina,
Thank you creating Octoprint!
