Can't install plugin on Octoprint Version 1.8.7
I want to install a plugin octolapse but i get error
Error!
Could not parse output from pip, see plugin_pluginmanager_console.log for generated output
I didn't find any solution for this topic. ![]()
octoprint-systeminfo-20230514185233.zip (11.7 KB)
Intel NUC
Windows 10
Creality Ender 3 pro
I'm a newbie if you need any information let me know
here is the complete install line
Installing plugin "Octolapse" from https://github.com/FormerLurker/Octolapse/archive/master.zip...
C:\OctoPrint\venv\Scripts\python.exe -m pip --disable-pip-version-check install file:///c:/users/passwo~1/appdata/local/temp/tmpli5_oo_p/octolapse-master.zip --no-cache-dir
Processing c:\users\passwo~1\appdata\local\temp\tmpli5_oo_p\octolapse-master.zip
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'error'
error: subprocess-exited-with-error
Getting requirements to build wheel did not run successfully.
exit code: 1
[20 lines of output]
likely tags: v0.4.3
picking v0.4.3
got version from expanded keyword {'version': 'v0.4.3', 'full-revisionid': '8d53c91069943b9b4d78498c2fc225b3d6d04cb8', 'dirty': False, 'error': None, 'date': '2023-05-13T12:58:31-0500'}
File "C:\OctoPrint\venv\lib\site-packages\pip_vendor\pyproject_hooks_in_process_in_process.py", line 353, in
main()
File "C:\OctoPrint\venv\lib\site-packages\pip_vendor\pyproject_hooks_in_process_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "C:\OctoPrint\venv\lib\site-packages\pip_vendor\pyproject_hooks_in_process_in_process.py", line 118, in get_requires_for_build_wheel
return hook(config_settings)
File "C:\Users\Password 0000\AppData\Local\Temp\pip-build-env-1ccwy9z3\overlay\Lib\site-packages\setuptools\build_meta.py", line 341, in get_requires_for_build_wheel
return self._get_build_requires(config_settings, requirements=['wheel'])
File "C:\Users\Password 0000\AppData\Local\Temp\pip-build-env-1ccwy9z3\overlay\Lib\site-packages\setuptools\build_meta.py", line 323, in _get_build_requires
self.run_setup()
File "C:\Users\Password 0000\AppData\Local\Temp\pip-build-env-1ccwy9z3\overlay\Lib\site-packages\setuptools\build_meta.py", line 487, in run_setup
super(_BuildMetaLegacyBackend,
File "C:\Users\Password 0000\AppData\Local\Temp\pip-build-env-1ccwy9z3\overlay\Lib\site-packages\setuptools\build_meta.py", line 338, in run_setup
exec(code, locals())
File "", line 57, in
ModuleNotFoundError: No module named 'octoprint'
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
exit code: 1
See above for output.
Error!
octoprint.log (73.2 KB)
plugin_pluginmanager_console.log (28.5 KB)
serial.log (149 Bytes)
