Can't install plugins from the menus.
Reviewed the logs, however, confused by what it wants.
https://pastebin.com/raw/vYgHA1Rv
Latest versions
RPI4
CalledProcessError: Command '('lsb_release', '-a')' returned non-zero exit status 1
I'm going to take an educated guess and say the installation has filesystem issues or there is something broken with the installation itself.
Got this: when typed it at a command prompt
File "/usr/bin/lsb_release", line 20, in
from optparse import OptionParser
File "/usr/lib/python3.7/optparse.py", line 90, in
from gettext import gettext, ngettext
ValueError: source code string cannot contain null bytes
Could it be an issue with having python 2.7 and 3.7 on the rpi4.
Shouldn't be. Would just make a backup of the pi home dir and reflash.
