Can't Load the web UI
I can't load the Web UI on any device
I've tried to re-install Octoprint on my Pi 3b, used a new SD card, changed the PI, I tried with my IP, IP:5000 and Octopi.local all with no joy.
If I look into my Router DHCP leases then I can see that the Octopi is active on the network I just can't connect to it for some reason.
I'm newish to Octoprint, if you can tell me how to get this without access to the UI then I am happy to try it.
I have just installed the latest stable version of Octoprint onto a Pi 3b using Pasbery pi imager, 64gb Micro SD card, Printer is an Ender 5 pro browser.. Chrome & edge no joy on either. The Pi connects to the network Wirelessly and I can see it on the DHCP list as active on the network.
also I use Home assistant (I'm sure some of you will know of it) to Automate my home and it will Automatically detect Octoprint but I can't connect as I can't open the UI
thank you for your help and time
kind regards
Robin
Hello @Survival_Student !
As some words are blue like
or
They ssem to be different.
Have you tried to click them?
Well I found my problem, nothing wrong with Octoprint, it's a faulty Pi, the WiFi has stopped working properly. My solution is to either conect a cable for netwrk connection or a new PI... new Pi it is..
