Can't log into my printer
I can't upload files to my Octoprint.
I rebooted the setup and now I can't log into the printer.
Advance scanner sees my printer's pi but I can't log into it. (I have 2 and the other printer is working fine.
no
na
I have the pi hardwired to the router.
This setup has worked for years and the issue started when I was trying to upload a print file and it was telling me the Octoprint server is not running.
Hello @testfly !
For clarification:
You can't login to OctoPrint, yes?
Do you get any connection at all or do you get an error screen?
Or can't connect OctoPrint to your printer?
