I can't login in to octoprint through my browser. I am able to connect via ssh though.
I did everything on the error page you get in your browser.
Latest version of octoprint, octopi 3B+, klipper firmware.
ValueError: bad marshal data (unknown type code)
2018-12-21 01:25:21,770 - octoprint.startup - INFO - ******************************************************************************
2018-12-21 01:25:21,772 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-12-21 01:25:21,775 - octoprint.startup - INFO - ******************************************************************************
2018-12-21 01:25:21,811 - octoprint.startup - CRITICAL - Could not initialize event manager: EOF read where object expected
2018-12-21 01:25:21,812 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
2018-12-21 01:36:59,931 - octoprint.startup - INFO - ******************************************************************************
2018-12-21 01:36:59,933 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-12-21 01:36:59,934 - octoprint.startup - INFO - ******************************************************************************
2018-12-21 01:36:59,945 - octoprint.startup - CRITICAL - Could not initialize event manager: EOF read where object expected
2018-12-21 01:36:59,946 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
2018-12-21 01:37:40,390 - octoprint.startup - INFO - ******************************************************************************
2018-12-21 01:37:40,392 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-12-21 01:37:40,393 - octoprint.startup - INFO - ******************************************************************************
2018-12-21 01:37:40,406 - octoprint.startup - CRITICAL - Could not initialize event manager: EOF read where object expected
2018-12-21 01:37:40,407 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
