Can't reach my OctoPi on my school's network
I can't reach the OctoPi instance when it's connected to my school's network.
I happen to be the network admin at my school, so I can see it on the network topology map: it gets an IP both via WiFi and Ethernet and I can even see it talking to the internet, but I am not able to access the web interface or even ping it, IP or octopi.local. I've tried giving it a static IP, but that didn't do anything. I've ensured it's on the correct vLAN.
When I connect it to my home network via Ethernet everything works fine, so this is probably a network issue, but I have no idea what it might be, so any help would be appreciated!
I can not access the Pi to get the logs, sorry.
I am using a Raspberry Pi B+ Rev 1.3 and a Windows laptop. It's a professional grade Ubiquity network, let me know if you need specifics.
Usually, school or enterprise networks have a 'Client isolation' type of feature. This disallows devices on the network from communicating with each other for security reasons. Very common on 'public' networks.
Sometimes, you can disable this per-device, I'm not familiar with your setup to say. You might be able to exempt your Pi from the isolation, so other computers can access it.
Aha, that makes a lot of sense! I'll look around and see if I can find a way to do that, thank you!
