I want to move the Webcam and Print Job History tab from the dropdown list to the left of the Temperature tab.
Attempted to edit .octoprint/config.yaml. Added text from https://docs.octoprint.org/en/master/configuration/config_yaml.html#appearance. I can move Control to the left of Terminal, but I've had no success attempting to move the Webcam and Print Job History entries. I can also successfully reorder the sidebar without any issues. I of course restarted OctoPrint after making the changes, and the Webcam and Print Job History tabs just won't move.
appearance:
color: default
colorTransparent: false
components:
disabled:
generic: []
navbar: []
settings: []
sidebar: []
tab: []
usersettings: []
order:
generic: []
navbar:
- settings
- systemmenu
- login
settings:
- section_printer
- serial
- printerprofiles
- temperatures
- terminalfilters
- gcodescripts
- section_features
- features
- webcam
- accesscontrol
- api
- section_octoprint
- folders
- appearance
- logs
sidebar:
- connection
- state
- files
- plugin_filamentmanager
tab:
- printjobhistory
- webcamtab
- temperature
- control
- gcodeviewer
- terminal
- timelapse
usersettings:
- access
- interface
defaultLanguage: null
2020-05-30 18:29:05,875 - octoprint.startup - INFO - ******************************************************************************
2020-05-30 18:29:05,877 - octoprint.startup - INFO - Starting OctoPrint 1.4.0
2020-05-30 18:29:05,879 - octoprint.startup - INFO - ******************************************************************************
2020-05-30 18:29:06,544 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2020-05-30 18:29:06,549 - octoprint.startup - INFO - Blacklist processing done, adding 1 blacklisted plugin versions: roomtemp (any)
2020-05-30 18:29:06,602 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-05-30 18:29:09,905 - octoprint.plugin.core - INFO - Found 26 plugin(s) providing 26 mixin implementations, 50 hook handlers
2020-05-30 18:29:10,241 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2020-05-30 18:29:10,268 - octoprint.server - INFO - Intermediary server started
2020-05-30 18:29:10,270 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2020-05-30 18:29:10,439 - octoprint.plugin.core - INFO - Found 26 plugin(s) providing 26 mixin implementations, 50 hook handlers
2020-05-30 18:29:10,474 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2020-05-30 18:29:10,938 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2020-05-30 18:29:10,943 - octoprint.server - INFO - Added new permission from plugin action_command_prompt: PLUGIN_ACTION_COMMAND_PROMPT_INTERACT (needs: u"Need(method='role', value=u'plugin_action_command_prompt_interact')")
2020-05-30 18:29:10,944 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_READ (needs: u"Need(method='role', value=u'plugin_announcements_read')")
2020-05-30 18:29:10,945 - octoprint.server - INFO - Added new permission from plugin announcements: PLUGIN_ANNOUNCEMENTS_MANAGE (needs: u"Need(method='role', value=u'plugin_announcements_manage'), Need(method='role', value=u'plugin_announcements_read')")
2020-05-30 18:29:10,946 - octoprint.server - INFO - Added new permission from plugin appkeys: PLUGIN_APPKEYS_ADMIN (needs: u"Need(method='role', value=u'plugin_appkeys_admin')")
2020-05-30 18:29:10,948 - octoprint.server - INFO - Added new permission from plugin backup: PLUGIN_BACKUP_ACCESS (needs: u"Need(method='role', value=u'plugin_backup_access')")
2020-05-30 18:29:10,950 - octoprint.server - INFO - Added new permission from plugin logging: PLUGIN_LOGGING_MANAGE (needs: u"Need(method='role', value=u'plugin_logging_manage')")
2020-05-30 18:29:10,951 - octoprint.server - INFO - Added new permission from plugin pi_support: PLUGIN_PI_SUPPORT_STATUS (needs: u"Need(method='role', value=u'plugin_pi_support_check')")
2020-05-30 18:29:10,953 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_MANAGE (needs: u"Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-05-30 18:29:10,955 - octoprint.server - INFO - Added new permission from plugin pluginmanager: PLUGIN_PLUGINMANAGER_INSTALL (needs: u"Need(method='role', value=u'plugin_pluginmanager_install'), Need(method='role', value=u'plugin_pluginmanager_manage')")
2020-05-30 18:29:10,957 - octoprint.server - INFO - Added new permission from plugin printer_safety_check: PLUGIN_PRINTER_SAFETY_CHECK_DISPLAY (needs: u"Need(method='role', value=u'plugin_printer_safety_check_display')")
2020-05-30 18:29:10,958 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_CHECK (needs: u"Need(method='role', value=u'plugin_softwareupdate_check')")
2020-05-30 18:29:10,960 - octoprint.server - INFO - Added new permission from plugin softwareupdate: PLUGIN_SOFTWAREUPDATE_UPDATE (needs: u"Need(method='role', value=u'plugin_softwareupdate_update')")
2020-05-30 18:29:11,002 - octoprint.plugins.PrintJobHistory - INFO - Start initializing
2020-05-30 18:29:11,004 - octoprint.plugins.PrintJobHistory.DatabaseManager - INFO - Init DatabaseManager
2020-05-30 18:29:11,005 - octoprint.plugins.PrintJobHistory.DatabaseManager - INFO - Creating database in: /home/pi/.octoprint/data/PrintJobHistory/printJobHistory.db
2020-05-30 18:29:11,007 - octoprint.plugins.PrintJobHistory.DatabaseManager - INFO - Check if database-scheme upgrade needed.
2020-05-30 18:29:11,024 - octoprint.plugins.PrintJobHistory.DatabaseManager - INFO - Done DatabaseManager.createDatabase
2020-05-30 18:29:11,024 - octoprint.plugins.PrintJobHistory.CameraManager - INFO - Init CameraManager
2020-05-30 18:29:11,025 - octoprint.plugins.PrintJobHistory.CameraManager - INFO - Snapshot-Folder:/home/pi/.octoprint/data/PrintJobHistory/snapshots
2020-05-30 18:29:11,026 - octoprint.plugins.PrintJobHistory.CameraManager - INFO - Done CameraMenager
2020-05-30 18:29:11,030 - octoprint.plugins.PrintJobHistory - INFO - Done initializing
2020-05-30 18:29:11,258 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2020-05-30 18:29:12,522 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-05-30 18:29:13,709 - octoprint.util.pip - INFO - Version of pip is 19.3.1
2020-05-30 18:29:13,712 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-05-30 18:29:13,712 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-05-30 18:29:13,718 - octoprint.plugin.core - INFO - Initialized 26 plugin implementation(s)
2020-05-30 18:29:13,741 - octoprint.plugin.core - INFO - 26 plugin(s) registered with the system:
| Bed Visualizer (0.1.13) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_bedlevelvisualizer
| DisplayLayerProgress Plugin (1.21.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_DisplayLayerProgress
| Filament Manager (0.5.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filamentmanager
| FileManager (0.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filemanager
| Login UI (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/loginui
| MQTT (0.8.7) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_mqtt
| Preheat Button (0.5.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_preheat
| PrintJobHistory (1.0.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintJobHistory
| Prusa Mesh Leveling (0.3.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrusaMeshMap
| Pushover (0.3.6) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_pushover
| Ultimaker Format Package (0.1.8) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_ultimakerformatpackage
| Webcam Tab (0.1.2) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_webcamtab
2020-05-30 18:29:13,760 - octoprint.environment - INFO - Detected environment is Python 2.7.16 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 917008384
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.17.0
| python:
| pip: 19.3.1
| version: 2.7.16
| virtualenv: /home/pi/oprint
2020-05-30 18:29:13,776 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2020-05-30 18:29:13,805 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2020-05-30 18:29:15,146 - octoprint.server - INFO - Shutting down intermediary server...
2020-05-30 18:29:15,320 - octoprint.server - INFO - Intermediary server shut down
2020-05-30 18:29:15,323 - octoprint.events - INFO - Processing startup event, this is our first event
2020-05-30 18:29:15,337 - octoprint.plugins.pushover - INFO - Got an event: Startup Payload: {}
2020-05-30 18:29:15,337 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2020-05-30 18:29:15,343 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2020-05-30 18:29:15,343 - octoprint.server - INFO - Autoconnect on startup is configured, trying to connect to the printer...
2020-05-30 18:29:15,349 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2020-05-30 18:29:15,403 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-05-30 18:29:15,426 - octoprint.plugins.pushover - INFO - Got an event: ConnectivityChanged Payload: {'new': True, 'old': False}
2020-05-30 18:29:17,136 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-05-30 18:29:17,160 - octoprint.server - INFO - Trying to connect to configured serial port None
2020-05-30 18:29:17,167 - octoprint.plugins.pushover - INFO - Got an event: Connecting Payload: {}
2020-05-30 18:29:17,225 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2020-05-30 18:29:17,238 - octoprint.plugins.pushover - INFO - Got an event: PrinterStateChanged Payload: {'state_string': u'Detecting serial port', 'state_id': 'DETECT_SERIAL'}
2020-05-30 18:29:17,245 - octoprint.server.util.watchdog - INFO - Running initial scan on watched folder...
2020-05-30 18:29:17,248 - octoprint.server.util.watchdog - INFO - ... initial scan done.
2020-05-30 18:29:17,271 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Prusa MK3"' for _http._tcp
2020-05-30 18:29:17,298 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance "Prusa MK3"' for _octoprint._tcp
2020-05-30 18:29:17,312 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "Prusa MK3" for SSDP
2020-05-30 18:29:17,391 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-05-30 18:29:17,419 - octoprint.plugins.pushover - INFO - Got an event: PrinterStateChanged Payload: {'state_string': u'Opening serial port', 'state_id': 'OPEN_SERIAL'}
2020-05-30 18:29:17,401 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2020-05-30 18:29:17,441 - octoprint.plugins.pushover - INFO - Got an event: PrinterStateChanged Payload: {'state_string': u'Detecting baudrate', 'state_id': 'DETECT_BAUDRATE'}
2020-05-30 18:29:17,552 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2020-05-30 18:29:17,683 - octoprint.plugins.mqtt - INFO - Connected to mqtt broker
2020-05-30 18:29:17,803 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2020-05-30 18:29:18,603 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-30 18:29:18,783 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting baudrate" to "Operational"
2020-05-30 18:29:18,801 - octoprint.plugins.pushover - INFO - Got an event: PrinterStateChanged Payload: {'state_string': u'Operational', 'state_id': 'OPERATIONAL'}
2020-05-30 18:29:18,872 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2020-05-30 18:29:18,873 - octoprint.plugins.pushover - INFO - Got an event: Connected Payload: {'baudrate': 0, 'port': None}
2020-05-30 18:29:19,466 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2020-05-30 18:29:19,468 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2020-05-30 18:29:19,469 - octoprint.util.pip - INFO - ==> pip ok -> yes
2020-05-30 18:29:19,609 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2020-05-30 18:29:19,630 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:172.16.1.4
2020-05-30 18:29:19,757 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:172.16.0.10
2020-05-30 18:29:19,866 - octoprint.plugins.PrintJobHistory - INFO - Plugin-State: PreHeat=enabled DisplayLayerProgress=enabled filamentmanager=enabled ultimakerformat=enabled
2020-05-30 18:29:19,875 - octoprint.plugins.bedlevelvisualizer - INFO - OctoPrint-BedLevelVisualizer loaded!
2020-05-30 18:29:19,940 - octoprint.server.util.flask - INFO - Passively logging in user jcw from ::ffff:172.16.0.10
2020-05-30 18:29:19,942 - octoprint.access.users - INFO - Logged in user: jcw
2020-05-30 18:29:20,004 - octoprint.server.util.sockjs - INFO - User jcw logged in on the socket from client ::ffff:172.16.0.10
2020-05-30 18:29:20,303 - octoprint.plugins.pushover - INFO - Connected to Pushover
2020-05-30 18:29:20,580 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi.private.com/'}
2020-05-30 18:29:20,876 - octoprint.server.util.flask - INFO - Passively logging in user jcw from ::ffff:172.16.1.4
2020-05-30 18:29:20,879 - octoprint.access.users - INFO - Logged in user: jcw
2020-05-30 18:29:20,907 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 12}
2020-05-30 18:29:21,176 - octoprint.server.util.sockjs - INFO - User jcw logged in on the socket from client ::ffff:172.16.1.4
2020-05-30 18:29:21,781 - octoprint.plugins.PrintJobHistory - INFO - Plugin-State: PreHeat=enabled DisplayLayerProgress=enabled filamentmanager=enabled ultimakerformat=enabled
2020-05-30 18:29:21,789 - octoprint.plugins.pushover - INFO - Got an event: ClientOpened Payload: {u'remoteAddress': u'::ffff:172.16.1.4'}
2020-05-30 18:29:22,041 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'plugins': u'displaylayerprogress:1.21.0,printjobhistory:1.0.0,filemanager:0.1.4,prusameshmap:0.3.0,mqtt:0.8.7,pushover:0.3.6,webcamtab:0.1.2,bedlevelvisualizer:0.1.13,ultimakerformatpackage:0.1.8,filamentmanager:0.5.3,preheat:0.5.1'}
2020-05-30 18:29:23,141 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.16', 'ram': 917008384, u'octopi_version': u'0.17.0', 'version': u'1.4.0', 'pip': '19.3.1', 'cores': 4, 'freq': 1200.0, u'pi_model': u'Raspberry Pi 3 Model B Rev 1.2', 'os': 'linux'}
2020-05-30 18:29:23,318 - octoprint.util.comm - INFO - Printer reports firmware name "Prusa-Firmware 3.9.0-RC1 based on Marlin"
2020-05-30 18:29:23,880 - octoprint.plugins.PrintJobHistory - INFO - Plugin-State: PreHeat=enabled DisplayLayerProgress=enabled filamentmanager=enabled ultimakerformat=enabled
2020-05-30 18:29:23,889 - octoprint.plugins.pushover - INFO - Got an event: ClientOpened Payload: {u'remoteAddress': u'::ffff:172.16.0.10'}
2020-05-30 18:29:23,909 - octoprint.plugins.pushover - INFO - Got an event: UserLoggedIn Payload: {'username': 'jcw'}
2020-05-30 18:29:23,924 - octoprint.plugins.pushover - INFO - Got an event: ClientAuthed Payload: {'username': 'jcw', 'remoteAddress': u'::ffff:172.16.0.10'}
2020-05-30 18:29:23,942 - octoprint.plugins.pushover - INFO - Got an event: UserLoggedIn Payload: {'username': 'jcw'}
2020-05-30 18:29:23,959 - octoprint.plugins.pushover - INFO - Got an event: ClientAuthed Payload: {'username': 'jcw', 'remoteAddress': u'::ffff:172.16.1.4'}
2020-05-30 18:29:24,009 - octoprint.plugins.pushover - INFO - Got an event: FirmwareData Payload: {'data': {u'EXTRUDER_COUNT': u'1', u'UUID': u'00000000-0000-0000-0000-000000000000', u'FIRMWARE_NAME': u'Prusa-Firmware 3.9.0-RC1 based on Marlin', u'MACHINE_TYPE': u'Prusa i3 MK3', u'PROTOCOL_VERSION': u'1.0', u'FIRMWARE_URL': u'https://github.com/prusa3d/Prusa-Firmware'}, 'name': u'Prusa-Firmware 3.9.0-RC1 based on Marlin'}
2020-05-30 18:29:24,815 - octoprint.server.util.flask - INFO - Passively logging in user jcw from ::ffff:172.16.1.4
2020-05-30 18:29:24,819 - octoprint.access.users - INFO - Logged in user: jcw
2020-05-30 18:29:24,869 - octoprint.plugins.pushover - INFO - Got an event: UserLoggedIn Payload: {'username': 'jcw'}
2020-05-30 18:29:25,143 - octoprint.plugins.tracking - INFO - Sent tracking event printer_connected, payload: {u'printer_baudrate': 0, u'printer_port': None, 'firmware_name': u'Prusa-Firmware 3.9.0-RC1 based on Marlin'}
2020-05-30 18:29:53,880 - octoprint.server.preemptive_cache - INFO - ... done in 33.30s
2020-05-30 18:29:55,508 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:172.16.1.4
2020-05-30 18:29:55,539 - octoprint.plugins.pushover - INFO - Got an event: ClientClosed Payload: {u'remoteAddress': u'::ffff:172.16.1.4'}
2020-05-30 18:29:55,963 - octoprint.server.util.flask - INFO - Passively logging in user jcw from ::ffff:172.16.1.4
2020-05-30 18:29:55,965 - octoprint.access.users - INFO - Logged in user: jcw
2020-05-30 18:29:56,001 - octoprint.plugins.pushover - INFO - Got an event: UserLoggedIn Payload: {'username': 'jcw'}
2020-05-30 18:29:59,173 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:172.16.1.4
2020-05-30 18:29:59,306 - octoprint.server.util.flask - INFO - Passively logging in user jcw from ::ffff:172.16.1.4
2020-05-30 18:29:59,308 - octoprint.access.users - INFO - Logged in user: jcw
2020-05-30 18:30:01,144 - octoprint.server.util.sockjs - INFO - User jcw logged in on the socket from client ::ffff:172.16.1.4
2020-05-30 18:30:01,321 - octoprint.plugins.PrintJobHistory - INFO - Plugin-State: PreHeat=enabled DisplayLayerProgress=enabled filamentmanager=enabled ultimakerformat=enabled
2020-05-30 18:30:01,342 - octoprint.plugins.pushover - INFO - Got an event: ClientOpened Payload: {u'remoteAddress': u'::ffff:172.16.1.4'}
2020-05-30 18:30:01,377 - octoprint.plugins.pushover - INFO - Got an event: UserLoggedIn Payload: {'username': 'jcw'}
2020-05-30 18:30:01,402 - octoprint.plugins.pushover - INFO - Got an event: ClientAuthed Payload: {'username': 'jcw', 'remoteAddress': u'::ffff:172.16.1.4'}
2020-05-30 18:44:10,245 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-05-30 18:44:20,814 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 912}
OctoPrint version 1.4.0
OctoPi version 0.17.0, running on Raspberry Pi 3 Model B Rev 1.2
Prusa MK3, firmware 3.9.0
Browser is Brave version 1.9.72 Chromium: 81.0.4044.138 (Official Build) (64-bit)
OS is Raspbian GNU/Linux 10 (buster)
