logitech c920
logitech c922
i cant get either camera to show up following @Charlie_Powell guide after doing a fresh install of octo print and octo dash on a new micro sd.
ensured i had them both inserted correctly. ensured I followed everything in the guide.
systemctl status webcamd.service
β webcamd.service - the OctoPi webcam daemon with the user specified config
Active: activating (start) since Mon 2021-08-02 21:41:43 EDT; 46s ago
Cntrl PID: 1492 (webcamd)
Tasks: 2 (limit: 4915)
ββ1492 /bin/bash /root/bin/webcamd
ββ1532 sleep 120
Aug 02 21:41:43 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
Aug 02 21:41:43 octopi root[1528]: Starting USB webcam
Aug 02 21:41:43 octopi mjpg_streamer[1529]: MJPG-streamer [1529]: starting application
Aug 02 21:41:43 octopi mjpg_streamer[1529]: MJPG-streamer [1529]: MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
Aug 02 21:41:43 octopi mjpg_streamer[1529]: MJPG-streamer [1529]: Using V4L2 device.: /dev/video1
Aug 02 21:41:43 octopi mjpg_streamer[1529]: MJPG-streamer [1529]: Desired Resolution: 1920 x 1080
Aug 02 21:41:43 octopi mjpg_streamer[1529]: MJPG-streamer [1529]: Frames Per Second.: 15
Aug 02 21:41:43 octopi mjpg_streamer[1529]: MJPG-streamer [1529]: Format............: JPEG
Aug 02 21:41:43 octopi mjpg_streamer[1529]: MJPG-streamer [1529]: TV-Norm...........: DEFAULT
Aug 02 21:41:43 octopi mjpg_streamer[1529]: MJPG-streamer [1529]: init_VideoIn failed
journalctl -xe
-- A start job for unit webcamd.service has finished with a failure.
-- The job identifier is 1214 and the job result is failed.
Aug 02 21:41:43 octopi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Aug 02 21:41:43 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 4.
-- Subject: Automatic restarting of a unit has been scheduled
-- Defined-By: systemd
-- Support: Debian -- Support
-- Automatic restarting of the unit webcamd.service has been scheduled, as the result for
-- the configured Restart= setting for the unit.
Aug 02 21:41:43 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
-- Subject: A stop job for unit webcamd.service has finished
-- A stop job for unit webcamd.service has finished.
-- The job identifier is 1271 and the job result is done.
-- Subject: A start job for unit webcamd.service has begun execution
-- A start job for unit webcamd.service has begun execution.
-- The job identifier is 1271.
Aug 02 21:43:13 octopi systemd[1]: webcamd.service: Start operation timed out. Terminating.
Aug 02 21:43:13 octopi systemd[1]: webcamd.service: Failed with result 'timeout'.
-- Subject: Unit failed
-- The unit webcamd.service has entered the 'failed' state with result 'timeout'.
Aug 02 21:43:13 octopi systemd[1]: Failed to start the OctoPi webcam daemon with the user specified config.
-- Subject: A start job for unit webcamd.service has failed
-- The job identifier is 1271 and the job result is failed.
Aug 02 21:43:15 octopi systemd[1]: webcamd.service: Service RestartSec=1s expired, scheduling restart.
Aug 02 21:43:15 octopi systemd[1]: webcamd.service: Scheduled restart job, restart counter is at 5.
Aug 02 21:43:15 octopi systemd[1]: Stopped the OctoPi webcam daemon with the user specified config.
-- The job identifier is 1328 and the job result is done.
Aug 02 21:43:15 octopi systemd[1]: Starting the OctoPi webcam daemon with the user specified config...
-- The job identifier is 1328.
Aug 02 21:43:15 octopi root[1579]: Starting USB webcam
Aug 02 21:43:15 octopi mjpg_streamer[1580]: MJPG-streamer [1580]: starting application
Aug 02 21:43:15 octopi mjpg_streamer[1580]: MJPG-streamer [1580]: MJPG Streamer Version: git rev: 5554f42c352ecfa7edaec6fc51e507afce605a34
Aug 02 21:43:15 octopi mjpg_streamer[1580]: MJPG-streamer [1580]: Using V4L2 device.: /dev/video1
Aug 02 21:43:15 octopi mjpg_streamer[1580]: MJPG-streamer [1580]: Desired Resolution: 1920 x 1080
Aug 02 21:43:15 octopi mjpg_streamer[1580]: MJPG-streamer [1580]: Frames Per Second.: 15
Aug 02 21:43:15 octopi mjpg_streamer[1580]: MJPG-streamer [1580]: Format............: JPEG
Aug 02 21:43:15 octopi mjpg_streamer[1580]: MJPG-streamer [1580]: TV-Norm...........: DEFAULT
Aug 02 21:43:15 octopi mjpg_streamer[1580]: MJPG-streamer [1580]: init_VideoIn failed
