I have the temp set to 275C for CF nylon and, every time I click the preset in the drop-down on the temp screen, it goes to 275, then changes to 260 after a second.
There is no print running or anything as I know the gcode has the temp in it and it overrides the OctoPrint setting (is there a way to disable this so it just uses the OctoPrint temp?) so I can't really think of a reason it keeps changing on its own.
Changed preset temps, rebooted everything, deleted gcode file off the OctoPrint.
I didn't even know there was a "safe mode"...
NA
Attached.
- OctoPrint 1.8.1
- Python 3.7.3
- OctoPi 0.18.0
- Ender 3 V2
- Firmware is that modified, aftermarket firmware...don't remember what it's called.
- Operating system?
octoprint-systeminfo-20220618075318.zip (41.4 KB)
