Since this morning I can't start Ocotprint, plugins can't load.
I tried to force-reinstall the plugins mentioned in the logs (slugify)
octoprint 1.3.9
octoPi version 0.15.1
list python plugins:
argh (0.26.2)
awesome-slugify (1.6.5)
Babel (2.5.3)
backports-abc (0.5)
backports.ssl-match-hostname (3.5.0.1)
blinker (1.4)
certifi (2018.4.16)
chainmap (1.0.2)
chardet (3.0.4)
click (6.2)
emoji (0.4.5)
feedparser (5.2.1)
Flask (0.10.1)
Flask-Assets (0.10)
Flask-Babel (0.9)
Flask-Login (0.2.11)
Flask-Principal (0.3.5)
frozendict (1.2)
future (0.15.2)
futures (3.1.1)
idna (2.6)
itsdangerous (0.24)
Jinja2 (2.8.1)
Markdown (2.6.11)
MarkupSafe (1.0)
monotonic (1.3)
netaddr (0.7.19)
netifaces (0.10.7)
OctoPrint (1.3.9)
OctoPrint-CustomControlPlugin (0.2.1)
OctoPrint-EditorCollection (0.1.2)
OctoPrint-FileManager (0.1.3)
OctoPrint-FirmwareUpdater (1.0.0)
OctoPrint-Fullscreen (0.0.4)
OctoPrint-Gcodebar (0.1.4)
OctoPrint-NavbarTemp (0.11)
OctoPrint-PrintTimeGenius (1.3)
OctoPrint-Stats (1.0.0)
OctoPrint-SystemCommandEditor (0.3.2)
pathtools (0.1.2)
pip (9.0.3)
pkg-resources (0.0.0)
pkginfo (1.4.2)
psutil (5.4.7)
pyasn1 (0.4.2)
pybonjour (1.1.1)
pylru (1.0.9)
pyserial (3.4)
python-dateutil (2.6.1)
python-slugify (1.2.6)
pytz (2018.4)
PyYAML (3.10)
regex (2018.2.21)
requests (2.20.0)
rsa (3.2.3)
sarge (0.1.4)
scandir (1.3)
semantic-version (2.4.2)
setuptools (39.1.0)
singledispatch (3.4.0.3)
six (1.11.0)
sockjs-tornado (1.0.3)
speaklater (1.3)
tornado (4.5.3)
Unidecode (0.4.21)
urllib3 (1.22)
watchdog (0.8.3)
webassets (0.12.1)
websocket-client (0.40.0)
Werkzeug (0.8.3)
wheel (0.31.0)
wrapt (1.10.11)
logs octoprint:
2018-11-09 10:14:32,305 - octoprint.startup - INFO - ******************************************************************************
2018-11-09 10:14:32,307 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-11-09 10:14:32,308 - octoprint.startup - INFO - ******************************************************************************
2018-11-09 10:14:32,383 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2018-11-09 10:14:32,387 - octoprint.startup - INFO - Blacklist processing done
2018-11-09 10:14:32,423 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-11-09 10:14:32,989 - octoprint.plugin.core - ERROR - Error loading plugin softwareupdate
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 847, in _import_plugin
instance = imp.load_module(key, f, filename, description)
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/init.py", line 26, in
from octoprint.server.util.flask import restricted_access, with_revalidation_checking, check_etag
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/server/init.py", line 65, in
from octoprint.printer.profile import PrinterProfileManager
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/printer/init.py", line 28, in
from octoprint.filemanager import FileDestinations
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/filemanager/init.py", line 18, in
from .storage import LocalFileStorage
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/filemanager/storage.py", line 27, in
from slugify import Slugify
File "/home/pi/oprint/local/lib/python2.7/site-packages/slugify/init.py", line 2, in
from slugify.main import Slugify, UniqueSlugify
ImportError: No module named main
2018-11-09 10:14:33,016 - octoprint.plugin.core - ERROR - Error loading plugin action_command_prompt
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt/init.py", line 9, in
from octoprint.server import user_permission
2018-11-09 10:14:33,050 - octoprint.plugin.core - ERROR - Error loading plugin logging
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/logging/init.py", line 10, in
from octoprint.server import NO_CONTENT, admin_permission
2018-11-09 10:14:33,126 - octoprint.plugin.core - ERROR - Error loading plugin pluginmanager
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/init.py", line 14, in
2018-11-09 10:14:33,302 - octoprint.plugin.core - ERROR - Error loading plugin announcements
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/announcements/init.py", line 23, in
from octoprint.server import admin_permission
2018-11-09 10:14:33,333 - octoprint.plugin.core - INFO - Plugin CuraEngine (<= 15.04) is disabled.
2018-11-09 10:14:33,362 - octoprint.plugin.core - ERROR - Error loading plugin printer_safety_check
File "/home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check/init.py", line 10, in
2018-11-09 10:14:33,976 - octoprint.plugin.core - ERROR - Error loading plugin stats
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_stats/init.py", line 10, in
from octoprint.server import printer
2018-11-09 10:14:34,023 - octoprint.plugin.core - ERROR - Error loading plugin PrintTimeGenius
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius/init.py", line 6, in
import octoprint.filemanager.storage
2018-11-09 10:14:34,104 - octoprint.plugin.core - ERROR - Error loading plugin firmwareupdater
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_firmwareupdater/init.py", line 17, in
import octoprint.server.util.flask
2018-11-09 10:14:34,138 - octoprint.plugin.core - ERROR - Error loading plugin filemanager
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filemanager/init.py", line 10, in
from octoprint.filemanager.destinations import FileDestinations
2018-11-09 10:14:34,215 - octoprint.plugin.core - INFO - Found 11 plugin(s) providing 10 mixin implementations, 8 hook handlers
2018-11-09 10:14:34,322 - octoprint.cli.server - ERROR - Uncaught exception
File "./octoprint", line 11, in
load_entry_point('OctoPrint==1.3.9', 'console_scripts', 'octoprint')()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/init.py", line 599, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 716, in call
return self.main(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 696, in main
rv = self.invoke(ctx)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 1060, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 889, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/core.py", line 534, in invoke
return callback(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/click/decorators.py", line 17, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 188, in serve_command
ignore_blacklist)
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 97, in run_server
from octoprint.server import Server
Thanks for your help !
