I have OctoPrint 1.3.12 running on OctoPi 0.16.0. As you can see i havent used the printer in a while and would like to update. However, when i try to do so, it always fails. This is also the case when updating plugins (telegram plugin for example).
I tried installing the filament manager plugin, it installed, but i cannot see it in the plugin list.
Different power suply, disconnected everything, restarted.
yes.
no.
since i am in an older version, i cant download systeminfo bundle, but i will include the following
octoprint (1).log (194.2 KB)
plugin_softwareupdate_console.log (228.1 KB)
Hello @TristanGB !
For you are running OctoPrint 1.3.12 on OctoPi 0.16.0 I would recommend to setup a whole new system.
You can backup your setup with the backup feature of OctoPrint and the new new installation fetches all plugins with the help of that backup file.
would all the configurations be copied as well?
Yes, it will be saved and restored
That's the meaning of a backup
I hate to rain on your parade but I don't think the backup feature of OctoPrint is going to do this across versions 1.3.12 to 1.6.? (the latest).
I'd start with a new SD card and a USB SD card reader/writer like https://www.amazon.com/Memory-Reader-Type-C-Adapter-Portable/dp/B07F6T9KHW or https://www.amazon.com/Memory-Reader-Type-C-Adapter-Portable/dp/B07F6T9KHW and then plug the old card into one of the RPi's USB ports, mount it, and copy the files you want to keep manually.
This USB SD card reader/writer can then be used later to backup the existing card on the RPi and other things.
It does older backups on newer versions, since it can upgrade the configuration - all the migrations stay in place. What it doesn't do is newer backups to older versions, since a new config scheme can be introduced that older versions don't understand.
