Hello
I have 2 sub-domains:
octopi.test -> for octopit , works perfectly
other.test -> for an nodejs app (use the localhost:3000)
Someone can help me with HaProxy or something ?
I don't really understand the redirect process of this stuff ^^'
when I try other.test.com it redirect me on the octopi instance
Used the magic of google, and used the search function in this great forum
Last stable release
Have a nice day (or night)
What's the primary domain? test.com is what it sounds like from your description.
Then it sounds like you have two DNS A records: octopi.test.com and other.test.com. Are these both the same server/host?
Try ping octopi.test.com. with a period at the end.
Try ping other.test.com. with a period at the end.
Honestly, the main instance of OctoPrint runs from ports 80, 5000 (and if there's a camera, possibly 8080 as well). If this is on the same server, then there's no reason to use DNS at all, 3000 should be able to co-exist nicely as octopi.test.com:3000.
