Centos 7 setup - No matching distribution found for octoprint
Trying to setup Octoprint via pip on Centos 7 server:
pip install octoprint -> "no matching distribution found for octoprint"
How can I fix this?
Thanks!
[root@sircentos OctoPrint]# python --version
Python 2.7.5
(venv) [root@sircentos OctoPrint]# pip install pip --upgrade
Successfully installed pip-19.3.1
(venv) [root@sircentos OctoPrint]# pip install octoprint
DEPRECATION: Python 2.7 will reach [...]
ERROR: Could not find a version that satisfies the requirement octoprint (from versions: none)
ERROR: No matching distribution found for octoprint
(venv) [root@sircentos OctoPrint]# pip install octoprint==1.3.12
ERROR: Could not find a version that satisfies the requirement octoprint==1.3.12 (from versions: none)
ERROR: No matching distribution found for octoprint==1.3.12
(venv) [root@sircentos OctoPrint]# pip install --no-cache-dir octoprint
Collecting octoprint
Could not find a version that satisfies the requirement octoprint (from versions: )
[root@sircentos ~]# yum update
No packages marked for update
[root@sircentos ~]# yum install python-pip python-devel python-setuptools python-virtualenv git libyaml-devel
Loaded plugins: fastestmirror, langpacks
Loading mirror speeds from cached hostfile
  • base: pkg.adfinis-sygroup.ch
  • epel: pkg.adfinis-sygroup.ch
  • extras: pkg.adfinis-sygroup.ch
  • updates: pkg.adfinis-sygroup.ch
    Package python2-pip-8.1.2-10.el7.noarch already installed and latest version
    Package python-devel-2.7.5-86.el7.x86_64 already installed and latest version
    Package python-setuptools-0.9.8-7.el7.noarch already installed and latest version
    Package python-virtualenv-15.1.0-2.el7.noarch already installed and latest version
    Package git-1.8.3.1-20.el7.x86_64 already installed and latest version
    Package libyaml-devel-0.1.4-11.el7_0.x86_64 already installed and latest version
    Nothing to do
I have installed too the "Development Tool" group.
[root@sircentos ~]# uname -a
Linux sircentos 3.10.0-1062.9.1.el7.x86_64 #1 SMP Fri Dec 6 15:49:49 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
[root@sircentos ~]# cat /etc/system-release
CentOS Linux release 7.7.1908 (Core)
In a case like this, it sounds like you might need to install it manually.
sudo yum install unzip
# Create the virtual environment
cd ~
virtualenv oprint
# Get the code
mkdir ~/OctoPrint
cd ~/OctoPrint
wget https://github.com/foosel/OctoPrint/archive/1.3.12.zip
unzip 1.3.12.zip
cd somewhere # (Do an ls and find out what folder is here, then cd into it)
# Activate the virtual environment
source ~/oprint/bin/activate
# Install OctoPrint from your local folder
pip install .
OctoPrint requires at least python 2.7.9. 2.7.5 is way way way too old.
Thank you for the reply.
This works as well!
That's true, infact the installation fails with the error:
OctoPrint requires Python '>=2.7.9,<3' but the running Python is 2.7.5
I have installed the 2.7.9 version but I'm not able to use it...
[root@sircentos ~]# python --version
Python 2.7.5
[root@sircentos ~]# python2.7 --version
Python 2.7.9
[root@sircentos OctoPrint]# virtualenv --python=/usr/bin/python2.7 venv
Running virtualenv with interpreter /usr/bin/python2.7
New python executable in /root/OctoPrint/venv/bin/python2.7
Also creating executable in /root/OctoPrint/venv/bin/python
Installing setuptools, pip, wheel...done.
[root@sircentos OctoPrint]# source venv/bin/activate
(venv) [root@sircentos OctoPrint]# python2.7 --version
Python 2.7.5
How can I solve?
Thanks.
Solved:
recompiling python was the solution, with some plus:
yum install openssl openssl-devel
cd /tmp/Python-2.7.9 [-setup folder-]
./configure
make
make altinstall
cd ~/OctoPrint
virtualenv -p python2.7 venv
Thanks.
