I am running Octopi behind my Synology NAS' reverse proxy. The webcam stream works perfectly from outside my network. But the Web UI part gets redirected to the Synology's UI because the NAS also uses port 5000.
Is there a way to change this back-end port?
Changed the back-end port to 5010 but this breaks the Octopi's UI.
OctoPrint version : 1.3.10
OctoPi version : 0.16.0
Line that I changed:
within:
sudo nano /etc/haproxy/haproxy.cfg:
global
maxconn 4096
user haproxy
group haproxy
log 127.0.0.1 local1 debug
defaults
log global
mode http
option httplog
option dontlognull
retries 3
option redispatch
option http-server-close
option forwardfor
maxconn 2000
timeout connect 5s
timeout client 15min
timeout server 15min
frontend public
bind :::2200 v4v6
bind :::443 v4v6 ssl crt /etc/ssl/snakeoil.pem
default_backend octoprint
backend octoprint
acl needs_scheme req.hdr_cnt(X-Scheme) eq 0
reqrep ^([^\ :]*)\ /(.*) \1\ /\2
reqadd X-Scheme:\ https if needs_scheme { ssl_fc }
reqadd X-Scheme:\ http if needs_scheme !{ ssl_fc }
option forwardfor
server octoprint1 127.0.0.1:5010
errorfile 503 /etc/haproxy/errors/503-no-octoprint.http
backend webcam
reqrep ^([^\ :]*)\ /webcam/(.*) \1\ /\2
server webcam1 127.0.0.1:8080
Error when changing the back-end port:
Octoprint log:
pi@octopi:~ $ cat ~/.octoprint/logs/octoprint.log
2019-03-15 01:28:59,581 - octoprint.startup - INFO - ******************************************************************************
2019-03-15 01:28:59,584 - octoprint.startup - INFO - Starting OctoPrint 1.3.10
2019-03-15 01:28:59,584 - octoprint.startup - INFO - ******************************************************************************
2019-03-15 01:29:00,907 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2019-03-15 01:29:00,979 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-03-15 01:29:03,908 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-03-15 01:29:04,046 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2019-03-15 01:29:04,103 - octoprint.server - INFO - Intermediary server started
2019-03-15 01:29:04,104 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2019-03-15 01:29:04,824 - octoprint.plugin.core - INFO - Found 15 plugin(s) providing 15 mixin implementations, 17 hook handlers
2019-03-15 01:29:04,869 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2019-03-15 01:29:04,871 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2019-03-15 01:29:04,894 - octoprint.plugins.tracking - INFO - Initialized anonymous tracking
2019-03-15 01:29:04,939 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2019-03-15 01:29:07,027 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-03-15 01:29:08,640 - octoprint.util.pip - INFO - Version of pip is 19.0.1
2019-03-15 01:29:08,642 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-03-15 01:29:08,642 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-03-15 01:29:08,648 - octoprint.plugin.core - INFO - Initialized 15 plugin implementation(s)
2019-03-15 01:29:08,659 - octoprint.plugin.core - INFO - 15 plugin(s) registered with the system:
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
2019-03-15 01:29:08,684 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
2019-03-15 01:29:08,700 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2019-03-15 01:29:08,719 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2019-03-15 01:29:09,150 - octoprint.server - INFO - Shutting down intermediary server...
2019-03-15 01:29:09,190 - octoprint.server - INFO - Intermediary server shut down
2019-03-15 01:29:09,192 - octoprint.events - INFO - Processing startup event, this is our first event
2019-03-15 01:29:09,193 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2019-03-15 01:29:09,195 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2019-03-15 01:29:09,200 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2019-03-15 01:29:09,219 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _http._tcp
2019-03-15 01:29:09,233 - octoprint.plugins.discovery - INFO - Registered 'OctoPrint instance on octopi' for _octoprint._tcp
2019-03-15 01:29:09,244 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2019-03-15 01:29:09,259 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2019-03-15 01:29:09,297 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-03-15 01:29:09,758 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-03-15 01:29:10,937 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python2 -m pip" as command to invoke pip
2019-03-15 01:29:10,939 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2019-03-15 01:29:10,939 - octoprint.util.pip - INFO - ==> pip ok -> yes
2019-03-15 01:29:10,997 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2019-03-15 01:29:11,023 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2019-03-15 01:29:11,556 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2019-03-15 01:29:11,649 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi.lan/'}
2019-03-15 01:29:12,112 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'python': '2.7.13', 'ram': 918188032, 'octopi_version': '0.16.0', 'version': u'1.3.10', 'pip': '19.0.1', 'cores': 4, 'freq': 1200.0, 'pi_model': 'Raspberry Pi 3 Model B Rev 1.2', 'os': 'linux'}
2019-03-15 01:29:24,127 - octoprint.server.preemptive_cache - INFO - ... done in 12.48s
2019-03-15 01:29:24,128 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi.lan:2200/'}
2019-03-15 01:29:36,602 - octoprint.server.preemptive_cache - INFO - ... done in 12.47s
2019-03-15 01:29:36,603 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=de', 'path': '/', 'base_url': 'http://octopi.lan/'}
2019-03-15 01:29:41,616 - octoprint.server.preemptive_cache - INFO - ... done in 5.01s
