Question: How to change the default BASEDIR from ~/.octoprint to something custom
I'm currently installing multiple instances of Octoprint on Raspberry Pi, which uses differing ports and appeared to work quite well. However, all share the same ~/.octoprint location for BASEDIR.
Looking at ./lib/python3.9/site-packages/octoprint/settings/init.py seems to suggest that if a basedir is provided then it will use that rather than the default.
What is the correct way to set the BASEDIR for Octoprint.settings.settings?
I've looked at the documentation here: octoprint.settings β OctoPrint master documentation but doesn't suggest where I should correctly set this, rather than hack the code around which will probably break with an update.
Not Relevant
Not Relevant
browser.user_agent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10.15; rv:109.0) Gecko/20100101 Firefox/113.0
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1500.0
env.hardware.ram: 3978645504
env.os.bits: 32
env.os.id: linux
env.os.platform: linux
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.1
env.python.pip: 20.3.4
env.python.version: 3.9.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.9.0
systeminfo.generated: 2023-06-02T16:41:47Z
systeminfo.generator: zipapi
OctoPrint version 1.9, OctoPi version 1.9, any, any, any, bullseye (Raspberry Pi), ... as much data as possible
V1.9
Raspberry Pi Bullseye 2Gb Pi 4
