Pi camera v2 connected to the pi4 2Gb that is running octopi
Resolution defaults to 640x480 and the FOV is quite bad on that
Been reading the forums/googling and found this https://picamera.readthedocs.io/en/release-1.12/fov.html#camera-modes so if I am reading it correctly 720p has better FOV than 1080p?
What exactly do I need to add to octopi.txt to correctly change the resolution/fps and the correct binning mode?
OctoPrint 1.4.2
Python 3.7.3
OctoPi 0.18.0
