Have tried several methods to change Hostname. Have a Pi on two different printers.
Have tried Raspberry Pi Imager advanced options. Have also tried creating octopi-hostname.txt both without success. The octopi-hostname.txt method the OS seems to want to load (I am on a MacBook) and the horizontal progress line under URL runs across, but never asks for Log In. Have also tried putting a blank SSH file in Boot SD and Terminal says Unknown Command when I send
run sudo raspi-config
I am beginning to wonder if macOS Monterey 12.2.1 has an issue with Raspberry Pi SSH. Have also tried to use Apple Terminal without success. When asked for password nothing is typed in so command is refused. Getting same results in Ezpi is reason I am pointing at MacOS. Realize you don't have control of MacOS.
This is intentional for Linux devices, when you receive the password prompt, type the password and press enter. You won't see it being typed but it should work.
Not sure what you are asking. After typing in password and hitting Enter it went back to asking for password. Did that 3 times and then if I remember correctly it kicked me out.
