What is the problem? I am using log2ram and would like to move all OctoPrint logs to /var/log/octoprint in order to reduce wear and tear on the SD card
What did you already try to solve it? I edited .octoprint/logging.yaml, but that only moved octoprint.log and serial log, not plugin_*.log
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ... as much data as possible) OctoPrint 1.4.0, RPi 3, Raspbian Jessie
