Each time I change my wifi SSID and password within the octopi-wpa-supplicant.txt, unmounting the SD card from my PC and than remounting it will result in the original settings be put back in the file. So no matter what I do the settings will always revert back to the old settings. I've also tried to copy the file and edit it from my local machine and then putting it on the SD card, but this will result in the file only showing ������....���� this weird question mark icon.
- Changing SD card readers. I've tried two
- Changing code editor. I tried Atom, VS code and Text edit
Logs (octoprint.log, serial.log or output on terminal tab, browser error console ...)
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, browser, operating system, ...)
- OctoPrint Version 1.3.11
- OctoPi Version 0.15.1
