My chrome browser (Version 83.0.4103.116 (Offizieller Build) (64-Bit)) freezes the octoprint tab after doing anything on the webinterface. Other browsers work and chrome works with everything else also flawless.
Removed all cookies and cleaned the browser's cache.
I don't find any issues inside the logs.
You kept the part of the template that says what to supply "at a minimum" and the statement "no logs, no support" yet you failed to provide anything for US to help you with except YOU didn't find any issues. Perhaps you might let US decide.
Having the same problems. Since a week (before I updated Chrome to 84.0.4147.89) the tabs with octoprint crash:
clicking update or ignore for a plugin from the notification popup.
at the end of a print, the last thing is the notification popup that a timelapse is being created
trying to setup a newly installed image (octopi 0.17.0) on a different pi, chrashes during wizard.
trying to enter the setup to figure out which version is currently running
Essentially everywhere.
BTW crashes means:
100+% CPU time
more more interaction possible in that tab
Closing the tab and opening a new one makes no difference. Shutting down chrome and trying again makes no difference. Even after a reboot: no difference.
