Tried with multiple config: HostIP (as the docker internal ip's network is bridged), the docker's internal ip, with 'localhost' and also with 127.0.0.1. Explicitly insert the port :80 and without it also. Relative path also not worked.
Here is the header of the snapshot - maybe this is not parsed well by the checker?:
It's worth to mention that in the Webcam&Timelaps menu's advanced configuration the 'Timeout' number and 'Snapshot url SSL validation' checkbox can not be modified, the configuration is not saved, a github issue is already opened.
Related timeout error:
2023-09-14T20:14:53.290203256Z 2023-09-14 22:14:53,283 - octoprint.server.api - ERROR - Error while running a test GET request on http://192.168.1.130/webcam/?action=snapshot
2023-09-14T20:14:53.290295238Z Traceback (most recent call last):
2023-09-14T20:14:53.290307042Z File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 200, in _new_conn
2023-09-14T20:14:53.290317658Z sock = connection.create_connection(
2023-09-14T20:14:53.290327925Z File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 85, in create_connection
2023-09-14T20:14:53.290338191Z raise err
2023-09-14T20:14:53.290348109Z File "/usr/local/lib/python3.8/site-packages/urllib3/util/connection.py", line 73, in create_connection
2023-09-14T20:14:53.290358725Z sock.connect(sa)
2023-09-14T20:14:53.290368433Z socket.timeout: timed out
2023-09-14T20:14:53.290378351Z
2023-09-14T20:14:53.290388269Z The above exception was the direct cause of the following exception:
2023-09-14T20:14:53.290398396Z
2023-09-14T20:14:53.290408174Z Traceback (most recent call last):
2023-09-14T20:14:53.290418301Z File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 790, in urlopen
2023-09-14T20:14:53.290428637Z response = self._make_request(
2023-09-14T20:14:53.290438695Z File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 496, in _make_request
2023-09-14T20:14:53.290480111Z conn.request(
2023-09-14T20:14:53.290490169Z File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 388, in request
2023-09-14T20:14:53.290500366Z self.endheaders()
2023-09-14T20:14:53.290510563Z File "/usr/local/lib/python3.8/http/client.py", line 1251, in endheaders
2023-09-14T20:14:53.290520341Z self._send_output(message_body, encode_chunked=encode_chunked)
2023-09-14T20:14:53.290530607Z File "/usr/local/lib/python3.8/http/client.py", line 1011, in _send_output
2023-09-14T20:14:53.290540874Z self.send(msg)
2023-09-14T20:14:53.290550792Z File "/usr/local/lib/python3.8/http/client.py", line 951, in send
2023-09-14T20:14:53.290560849Z self.connect()
2023-09-14T20:14:53.290570487Z File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 236, in connect
2023-09-14T20:14:53.290580964Z self.sock = self._new_conn()
2023-09-14T20:14:53.290590812Z File "/usr/local/lib/python3.8/site-packages/urllib3/connection.py", line 209, in _new_conn
2023-09-14T20:14:53.290601009Z raise ConnectTimeoutError(
2023-09-14T20:14:53.290611136Z urllib3.exceptions.ConnectTimeoutError: (<urllib3.connection.HTTPConnection object at 0x7f14b524faf0>, 'Connection to 192.168.1.130 timed out. (connect timeout=5.0)')
2023-09-14T20:14:53.290621822Z
2023-09-14T20:14:53.290631530Z The above exception was the direct cause of the following exception:
2023-09-14T20:14:53.290641098Z
2023-09-14T20:14:53.290650387Z Traceback (most recent call last):
2023-09-14T20:14:53.290660654Z File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 486, in send
2023-09-14T20:14:53.290670781Z resp = conn.urlopen(
2023-09-14T20:14:53.290682864Z File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 844, in urlopen
2023-09-14T20:14:53.290693340Z retries = retries.increment(
2023-09-14T20:14:53.290703188Z File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 515, in increment
2023-09-14T20:14:53.290713385Z raise MaxRetryError(_pool, url, reason) from reason # type: ignore[arg-type]
2023-09-14T20:14:53.290723582Z urllib3.exceptions.MaxRetryError: HTTPConnectionPool(host='192.168.1.130', port=80): Max retries exceeded with url: /webcam/?action=snapshot (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f14b524faf0>, 'Connection to 192.168.1.130 timed out. (connect timeout=5.0)'))
2023-09-14T20:14:53.290734687Z
2023-09-14T20:14:53.290744185Z During handling of the above exception, another exception occurred:
2023-09-14T20:14:53.290754382Z
2023-09-14T20:14:53.290764160Z Traceback (most recent call last):
2023-09-14T20:14:53.290774078Z File "/octoprint/plugins/lib/python3.8/site-packages/octoprint/server/api/__init__.py", line 657, in _test_url
2023-09-14T20:14:53.290784415Z with requests.request(
2023-09-14T20:14:53.290803132Z File "/usr/local/lib/python3.8/site-packages/requests/api.py", line 59, in request
2023-09-14T20:14:53.290813748Z return session.request(method=method, url=url, **kwargs)
2023-09-14T20:14:53.290824365Z File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 589, in request
2023-09-14T20:14:53.290834562Z resp = self.send(prep, **send_kwargs)
2023-09-14T20:14:53.290844409Z File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 703, in send
2023-09-14T20:14:53.290854606Z r = adapter.send(request, **kwargs)
2023-09-14T20:14:53.290864594Z File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 507, in send
2023-09-14T20:14:53.290874651Z raise ConnectTimeout(e, request=request)
2023-09-14T20:14:53.290884708Z requests.exceptions.ConnectTimeout: HTTPConnectionPool(host='192.168.1.130', port=80): Max retries exceeded with url: /webcam/?action=snapshot (Caused by ConnectTimeoutError(<urllib3.connection.HTTPConnection object at 0x7f14b524faf0>, 'Connection to 192.168.1.130 timed out. (connect timeout=5.0)'))
