I have inherited a preconfigured Ocotprint installation. However, it is filled with the previous kind user's information and usage data. I need to remove all the old configs such as passwords, filament data, gcode, etc from that user.
Is there a script or procedure that I can use that will do this for me?
Don't know where to start!
NA
NA
System Information
OctoPrint 1.7.2
Python 3.7.3
OctoPi 0.18.0
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/96.0.4664.45 Safari/537.36
connectivity.connection_check : 1.1.1.1:53
connectivity.connection_ok : True
connectivity.enabled : True
connectivity.online : True
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : True
env.hardware.cores : 4
env.hardware.freq : 1500.0
env.hardware.ram : 1904381952
env.os.bits : 32
env.os.id : linux
env.os.platform : linux
env.plugins.pi_support.model : Raspberry Pi 4 Model B Rev 1.4
env.plugins.pi_support.octopi_version : 0.18.0
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 20.3.3
env.python.version : 3.7.3
env.python.virtualenv : True
octoprint.safe_mode : False
octoprint.version : 1.7.2
systeminfo.generator : zipapi
octoprint.log
27.85K chars
253 lines
serial.log
444 chars
3 lines
terminal.txt
11.85K chars
300 lines
plugin_softwareupdate_console.log
494.35K chars
3.18K lines
β
2021-02-05 15:38:29,382 /home/pi/oprint/bin/python3 -m pip --disable-pip-version-check install https://github.com/OctoPrint/OctoPrint-FirmwareCheck/archive/2021.2.4.zip --no-cache-dir 2021-02-05 15:38:31,418 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple 2021-02-05 15:38:31,420 > Collecting https://github.com/OctoPrint/OctoPrint-FirmwareCheck/archive/2021.2.4.zip 2021-02-05 15:38:32,422 > Downloading https://github.com/OctoPrint/OctoPrint-FirmwareCheck/archive/2021.2.4.zip (66 kB) 2021-02-05 15:38:33,426 > Building wheels for collected packages: OctoPrint-FirmwareCheck 2021-02-05 15:38:33,426 > Building wheel for OctoPrint-FirmwareCheck (setup.py): started 2021-02-05 15:38:35,033 > Building wheel for OctoPrint-FirmwareCheck (setup.py): finished with status 'done' 2021-02-05 15:38:35,033 > Created wheel for OctoPrint-FirmwareCheck: filename=OctoPrint_FirmwareCheck-2021.2.4-py2.py3-none-any.whl size=30743 sha256=068838affa296ea6f9dae46ba964b462a00c884f2d103b98b47b77e5236a0b6e 2021-02-05 15:38:35,033 > Stored in directory: /tmp/pip-ephem-wheel-cache-_gmlf0n1/wheels/b8/42/78/87046299527ed1affa9ab5724c2d69f62681848204a9bd3639 2021-02-05 15:38:35,034 > Successfully built OctoPrint-FirmwareCheck 2021-02-05 15:38:35,034 > Installing collected packages: OctoPrint-FirmwareCheck 2021-02-05 15:38:35,034 > Attempting uninstall: OctoPrint-FirmwareCheck 2021-02-05 15:38:35,034 > Found existing installation: OctoPrint-FirmwareCheck 2020.9.23 2021-02-05 15:38:35,034 > Uninstalling OctoPrint-FirmwareCheck-2020.9.23: 2021-02-05 15:38:35,034 > Successfully uninstalled OctoPrint-FirmwareCheck-2020.9.23 2021-02-05 15:38:35,035 > Successfully installed OctoPrint-FirmwareCheck-2021.2.4 2021-02-05 15:38:35,154 /home/pi/oprint/bin/python3 -m pip --disable-pip-version-check install https://github.com/LazeMSS/OctoPrint-UICustomizer/archive/0.1.2.8.zip --no-cache-dir 2021-02-05 15:38:37,566 > Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple 2021-02-05 15:38:37,567 > Collecting https://github.com/LazeMSS/OctoPrint-UICustomizer/archive/0.1.2.8.zip 2021-02-05 15:38:37,568 > Downloading https://github.com/LazeMSS/OctoPrint-UICustomizer/archive/0.1.2.8.zip (1.8 MB) 2021-02-05 15:38:41,307 > Requirement already satisfied: OctoPrint in /home/pi/oprint/lib/python3.7/site-packages (from UI-Customizer==0.1.2.8) (1.5.3) 2021-02-05 15:38:41,307 > Requirement already satisfied: itsdangerous<2,>=1.1.0 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->UI-Customizer==0.1.2.8) (1.1.0) 2021-02-05 15:38:41,308 > Requirement already satisfied: filetype<2,>=1.0.7 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->UI-Customizer==0.1.2.8) (1.0.7) 2021-02-05 15:38:41,308 > Requirement already satisfied: rsa==4.0 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->UI-Customizer==0.1.2.8) (4.0) 2021-02-05 15:38:41,308 > Requirement already satisfied: Flask-Assets<3,>=2.0 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->UI-Customizer==0.1.2.8) (2.0) 2021-02-05 15:38:41,308 > Requirement already satisfied: PyYAML<6,>=5.3.1 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->UI-Customizer==0.1.2.8) (5.3.1) 2021-02-05 15:38:41,308 > Requirement already satisfied: Flask-Babel<2,>=1.0 in /home/pi/oprint/lib/python3.7/site-packages (from OctoPrint->UI-Customizer==0.1.2.8) (1.0.0)
plugin_pluginmanager_console.log
22.63K chars
130 lines
haproxy.log
21.85K chars
96 lines
plugin_softwareupdate_update.log
1.09K chars
6 lines
webcamd.log
355.1M chars
10.25M lines
Β© 2021 OctoPrint Β· Imprint Β· Privacy Policy
