I had an EMI Problem which I solved with an USV. But I have now an old issue. I can open the octopi webpage and start a print. This print runs fine as long as I keep the webpage open. As soon as I close the browser, the printer stopps after some time. And "connection failed" will start then. I can even fire up prints and close the browser after the start of the print and the same happens. As long as the browser runs, the printer doesnt have the issue. I printed something yesterday for around 8-10 hours until did go to bed and closed the browser.
I did deactivate all plugins, had this same behavior with an other board (pi2 upgraded to pi3).
no, I use PSU control to power the printer. Thats Why I need the plugins to run the printer.
I will try that shortly, but need to change the wiring.
(untested)
octoprint-systeminfo-20240411095832.zip (64.3 KB)
I use latest chrome to open the webpanel. I did remove -y from webcam and downgraded to 640x480 again, as the webcam seams unstable with higher settings. -y fixed an issue where white/Black bars like waves go from top to bottom always. with -y I hade way less, but think thats because of the cam... will ignore them for now.
