ODROID c1+, self installed
After connecting OCTOPRINT with my Ender 3, octoprint get some information about the printer, and than it stuck and (maybe) waiting for a "ok"
Giving the user tty and dialout groups
Complete Logs
2020-11-08 13:39:33,334 - Changing monitoring state from "Offline" to "Detecting serial connection"
2020-11-08 13:39:33,532 - Performing autodetection with 3 port/baudrate candidates: /dev/ttyACM0@250000, /dev/ttyS2@250000, /dev/ttyS0@250000
2020-11-08 13:39:33,534 - Trying port /dev/ttyACM0, baudrate 250000
2020-11-08 13:39:33,536 - Connecting to port /dev/ttyACM0, baudrate 250000
2020-11-08 13:39:33,545 - Handshake attempt #1 with timeout 2.0s
2020-11-08 13:39:33,549 - Connected to: Serial<id=0xac11b208, open=True>(port='/dev/ttyACM0', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-11-08 13:39:33,551 - Send: N0 M110 N0125
2020-11-08 13:39:33,558 - Recv: ok
2020-11-08 13:39:33,606 - Changing monitoring state from "Detecting serial connection" to "Operational"
2020-11-08 13:39:33,620 - Send: N0 M110 N0125
2020-11-08 13:39:33,656 - Recv: ok
2020-11-08 13:39:33,659 - Send: N1 M115*39
2020-11-08 13:39:33,687 - Recv: FIRMWARE_NAME:Marlin bugfix-2.0.x (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:SKR-mini-E3-V1.2 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2020-11-08 13:39:33,691 - Recv: Cap:SERIAL_XON_XOFF:0
2020-11-08 13:39:33,692 - Recv: Cap:BINARY_FILE_TRANSFEap:SOFTWARE_POWER:0
2020-11-08 13:39:33,694 - Recv: Cap:TOGGLE_LIGHTS:0
- I PRESS FAKE OK * (M105)
2020-11-08 13:39:52,667 - Recv: Cap:CASE_LIGHT_BRIGHTNok T:20.62 /0.00 B:20.62 /0.00 @:0 B@:0
2020-11-08 13:39:54,991 - Send: G91
2020-11-08 13:39:55,001 - Recv: ok
2020-11-08 13:39:55,003 - Send: G28 X0 Y0
no it works without any issues
Pyhton 3.8.5
Octoprint 1.4.2
Odroid c1+
Ender 3 (SKR MINI)
Printer firmware see in log
