Communication error
There was a communication error while talking to your printer. Please consult the terminal output and octoprint.log for details. Error: Printer keeps requesting line 70923 again and again, communication stuck
State: Offline after error
---Recv: echo:busy: processing
Recv: T:199.20 /0.00 B:58.89 /0.00 @:0 B@:0
Recv: ok
Changing monitoring state from "Printing" to "Finishing"
Send: N70921 M117 0% L=224/22498
Recv: ok
Send: N70922 M40041
Recv: ok
Send: {if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+2, max_print_height)} F600
Send: N70923 G1 X5 Y{print_bed_max[1]0.85} F{travel_speed60}17
Recv: echo:Unknown command: "{if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+2, max_print_height)} F600"
Recv: ok
Recv: Error:checksum mismatch, Last Line: 70922
Recv: Resend: 70923
Send: N70924 M117 100% L=224/224102
Recv: ok
Send: N70924 M117 100% L=224/224*102
Recv: Error:Line Number is not Last Line Number+1, Last Line: 70922
Recv: Resend: 70923
Recv: ok
Recv: Resend: 70923
Recv: ok
Recv: Resend: 70923
Recv: ok
Recv: Error:No Line Number with checksum, Last Line: 70922
Recv: Resend: 70923
Recv: ok
Send: N70923 G1 X5 Y{print_bed_max[1]0.85} F{travel_speed60}*17
Recv: Resend: 70923
Recv: ok
Recv: Resend: 70923
Recv: ok
Recv: Resend: 70923
Recv: ok
Recv: Resend: 70923
Recv: ok
Recv: Resend: 70923
Recv: ok
Recv: Resend: 70923
Recv: ok
Recv: Resend: 70923
Changing monitoring state from "Finishing" to "Error"
Send: M112
Send: N70925 M11240
Send: N70926 M104 T0 S043
Send: N70927 M140 S0110
Closing down send loop
