I've had a few prints fail due to a comms issue between the Pi and my Ender 3 Pro which I would like to resolve, but at the moment I do not have access to the log files (I am at work and my Octoprint is only accessible locally) So for now I would like to know if there are any common issues with the Ender 3 and lost comms? I will post more details this evening to help diagnose my specific issue.
Last night I had a comms failure about 10 hours in to a 14 hour print job, it was my second attempt at the same part so I was keen to recover it, I started out by looking in the terminal screen for the last command sent to the printer, I then searched this out in the .gcode file and set about removing everything before this point.
On my first attempt I forgot to remove the prime line code from the beginning and on starting my print head crashed in to the part, fortunately nothing was moved or damaged so after removing the prime line code I tried again, this time with more success, the head moved towards where it had stopped and began printing, but it missed around 3-4 lines of extrusion, lucky for me this was a top layer of a large flat which was going to be "ironed" on a second pass and the ironing filled in the missing area without leaving a trace.
The next and all remaining layer to go down is entirely walling so I let a few layers go down, before realising that the fan was not running (I had deleted the line of code that started the fan) I manually started the fan it was getting late so i went to bed leaving the print job to run its course. This morning I found that the job had run to completion but there was a weak layer where the fan had not been running.
Overall i was pleased with my attempt at recovering the print job, had i not messed up with the fan i'm sure it would have been saved. Can anyone tell me the Gcode used to control the fan?
if i know this i can ensure that i add the code to start the fan.
Also how big is the buffer on the Ender3 Pro? is it a set number of lines or a certain size of data, is there an easy way of working out how many lines of code the printer is lagging behind the data sent out by Octoprint so that I can resume on the same line as where it cut off?
