After the update to 1.7.3 I am seeing communication errors on my prusa with MMU.
I am using prusa slicer setup for the MMU but in single filament mode. I start the job and the printer asked me what filament I want to use. I choose filament 1 and it loads the filament and starts to head up the bed and hot end. 33% of the time today I saw it was just about to start the bed Z probe and the printer reset.
At no point does it stop talking to the prusa and I can see the logging and temperature change.
if I try printing the same file again it sometimes worked
no
no
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Send: N81 M10530
Recv: T:239.5 /240.0 B:83.9 /85.0 T0:239.5 /240.0 @:41 B@:103 P:0.0 A:28.3
Recv: T:239.92 E:0 B:83.9
Recv: T:240.10 E:0 B:84.0
Recv: T:240.0 /240.0 B:84.0 /85.0 T0:240.0 /240.0 @:32 B@:107 P:0.0 A:28.4
Send: N82 M10529
Recv: T:239.92 E:0 B:84.2
Recv: T:240.0 /240.0 B:84.1 /85.0 T0:240.0 /240.0 @:32 B@:97 P:0.0 A:28.4
Recv: T:240.00 E:0 B:84.2
Send: N83 M10528
Recv: T:239.9 /240.0 B:84.2 /85.0 T0:239.9 /240.0 @:33 B@:95 P:0.0 A:28.4
Recv: T:239.92 E:0 B:84.3
Recv: T:240.00 E:0 B:84.4
Recv: T:239.7 /240.0 B:84.5 /85.0 T0:239.7 /240.0 @:37 B@:78 P:0.0 A:28.4
Recv: T:240.00 E:0 B:84.5
Send: N84 M10527
Recv: T:240.10 E:0 B:84.6
Recv: T:239.8 /240.0 B:84.6 /85.0 T0:239.8 /240.0 @:36 B@:56 P:0.0 A:28.2
Recv: T:239.77 E:0 B:84.6
Recv: T:240.10 E:0 B:84.8
Send: N85 M10526
Recv: T:239.5 /240.0 B:84.8 /85.0 T0:239.5 /240.0 @:39 B@:53 P:0.0 A:28.0
Recv: T:239.53 E:0 B:84.8
Recv: T:240.21 E:0 B:84.8
Recv: T:239.92 E:0 B:84.9
Send: N86 M10525
Recv: T:240.2 /240.0 B:84.9 /85.0 T0:240.2 /240.0 @:28 B@:49 P:0.0 A:28.5
Recv: T:239.84 E:0 B:84.9
Recv: LCD status changed
Recv: ok
Recv: Full RX Buffer
Send: N87 M117 [SP] Printing 0%26
Recv: ok
Send: N88 M117 [SP] Printing 0%21
Recv: ok T:239.8 /240.0 B:85.0 /85.0 T0:239.8 /240.0 @:35 B@:41 P:0.0 A:28.1
Send: N89 M117 [SP] Printing 0%20
Recv: Error:Line Number is not Last Line Number+1, Last Line: 18
Recv: Resend: 19
Should resend line 19 but no sufficient history is available, can't resend
Changing monitoring state from "Printing" to "Error"
Send: M112
Send: N90 M11224
Send: N91 M104 T0 S025
Send: N92 M140 S094
Closing down send loop
- OctoPrint 1.7.3
- Python 3.7.3
- OctoPi 0.18.0
Prusa Mk3s+ with MMU
SImply print 3.1.1
Hello @leesmithsworkshop !
You may check your printer first. Lose cables etc.
There are some diagnosis routines inside the firmware.
HI, I know this is not the problem, I went through and checked everything after the first time and the only change is the octoprint update and it worked fine for months before. It happened again this morning and I just tried to print again and it worked. If it was a connection problem I would loose communication with the printer, but it never does.
out of interest I will load the file to the sd card and try that a few times.
it's printing as normal from the sd card.
Then please enable the serial.log, try to print again and after the error occurs please share the systeminfo bundle in the next post.
I printing from octoprint again and 2 prints have been ok, but I see this in the terminal.Recv: echo:busy: processing
Recv: MMU => 'ok'
Recv: mmu_get_response() returning: 1
Recv: ok
Send: N17 M108*28
Recv: ok
Send: N48 M117 [SP] Printing 0%*25
Recv: Unknown M code: $17 M108
Recv: ok
Send: N49 M107*24
Recv: Resend: 19
Recv: ok
Please share the systeminfo bundle
octoprint-systeminfo-20220131161619.zip (1.4 MB)
This was from a completed print, but it still has those same errors.
Please turn off DEBUG. From 47508 lines in the octoprint.log, just 452 are helpful.
Have you already tried safe mode?
The problem begins with line N17. I assume it's generated by SimplyPrint
2022-01-31 14:42:57,036 - Send: N17 M117 [SP] Printing 0%*19
2022-01-31 14:42:57,049 - Recv: T:188.6 /240.0 B:67.1 /85.0 T0:188.6 /240.0 @:127 B@:127 P:0.0 A:40.1
2022-01-31 14:42:57,052 - Recv: LCD status changed
2022-01-31 14:42:58,041 - Recv: T:191.05 E:0 B:67.4
2022-01-31 14:42:59,044 - Recv: T:193.98 E:0 B:67.7
2022-01-31 14:42:59,142 - Recv: T:194.5 /240.0 B:67.8 /85.0 T0:194.5 /240.0 @:127 B@:127 P:0.0 A:40.0
2022-01-31 14:43:00,044 - Recv: T:196.41 E:0 B:67.9
2022-01-31 14:43:00,046 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
I will disable all plugins and try again tomorrow.
I have this same setup on 5 others and I never see these communications warnings, it's only on the prusa with mmu.
with simplyprint disable I don't see any of the communication messages
Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
Trying port /dev/ttyACM0, baudrate 115200
Connecting to port /dev/ttyACM0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0x6d98df10, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0*125
Recv: start
Changing monitoring state from "Detecting serial connection" to "Operational"
Recv: echo: 3.10.0-4481
Recv: echo: Last Updated: May 6 2021 13:52:17 | Author: (none, default config)
Recv: Compiled: May 6 2021
Recv: echo: Free Memory: 2054 PlannerBufferBytes: 1760
Recv: echo:Hardcoded Default Settings Loaded
Recv: adc_init
Recv: Extruder fan type: NOCTUA
Recv: CrashDetect ENABLED!
Recv: FSensor ENABLED (sensor board revision: 0.4 or newer)
Recv: Sending 0xFF
Recv: echo:SD card ok
Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
Recv: ok
Send: N1 M115*39
Recv: FIRMWARE_NAME:Prusa-Firmware 3.10.0 based on Marlin FIRMWARE_URL:https://github.com/prusa3d/Prusa-Firmware PROTOCOL_VERSION:1.0 MACHINE_TYPE:Prusa i3 MK3S EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:AUTOREPORT_FANS:1
Recv: Cap:AUTOREPORT_POSITION:1
Recv: Cap:EXTENDED_M20:1
Recv: ok
Send: M21
Recv: Sending 0xFF
Recv: ok
Send: M20
Recv: Begin file list
Recv: PRUSA_~3.GCO 409063
Recv: PRUSA_~1.GCO 318314
Recv: WHISTL~1.GCO 857259
Recv: BATMAN~1.GCO 232720
Recv: 3DHUBS~1.GCO 2088342
Recv: BUDDY_~1.GCO 8397671
Recv: 3DBENC~1.GCO 6726610
Recv: PRUSAB~1.GCO 1825245
Recv: TREEFR~1.GCO 6217854
Recv: PRUSA_~2.GCO 318319
Recv: GEAR_B~1.GCO 10487787
Recv: TRICER~1.GCO 17667627
Recv: VASE_0~1.GCO 7626315
Recv: NEFERT~1.GCO 19957727
Recv: ADALIN~1.GCO 23529730
Recv: CASTLE~1.GCO 25407551
Recv: 3DBENC~2.GCO 4611845
Recv: BL_TOU~1.GCO 1000375
Recv: XYSUPP~1.GCO 1602020
Recv: End file list
Recv: ok
Send: M113 S2
Recv: ok
Send: M105
Recv: ok T:19.0 /0.0 B:18.3 /0.0 T0:19.0 /0.0 @:0 B@:0 P:0.0 A:24.0
Send: M155 S2
Recv: ok
Recv: MMU => 'start'
Recv: MMU <= 'S1'
Recv: T:19.9 /0.0 B:19.2 /0.0 T0:19.9 /0.0 @:0 B@:0 P:0.0 A:24.1
Recv: T:19.7 /0.0 B:19.1 /0.0 T0:19.7 /0.0 @:0 B@:0 P:0.0 A:24.0
Recv: MMU => '106ok'
Recv: MMU <= 'S2'
Recv: MMU => '372ok'
Recv: MMU version valid
Recv: MMU <= 'M1'
Recv: MMU - ENABLED
Recv: T:19.6 /0.0 B:19.3 /0.0 T0:19.6 /0.0 @:0 B@:0 P:0.0 A:23.7
Recv: T:19.5 /0.0 B:19.2 /0.0 T0:19.5 /0.0 @:0 B@:0 P:0.0 A:24.1
Recv: T:19.7 /0.0 B:19.4 /0.0 T0:19.7 /0.0 @:0 B@:0 P:0.0 A:24.2
Recv: T:19.4 /0.0 B:19.1 /0.0 T0:19.4 /0.0 @:0 B@:0 P:0.0 A:23.9
Recv: T:19.6 /0.0 B:18.9 /0.0 T0:19.6 /0.0 @:0 B@:0 P:0.0 A:24.1
Recv: T:19.3 /0.0 B:19.0 /0.0 T0:19.3 /0.0 @:0 B@:0 P:0.0 A:24.2
Recv: T:19.4 /0.0 B:19.0 /0.0 T0:19.4 /0.0 @:0 B@:0 P:0.0 A:24.1
Recv: T:19.4 /0.0 B:18.8 /0.0 T0:19.4 /0.0 @:0 B@:0 P:0.0 A:24.1
Recv: T:19.4 /0.0 B:18.8 /0.0 T0:19.4 /0.0 @:0 B@:0 P:0.0 A:24.3
Recv: T:19.2 /0.0 B:18.8 /0.0 T0:19.2 /0.0 @:0 B@:0 P:0.0 A:24.1
Recv: T:19.3 /0.0 B:19.0 /0.0 T0:19.3 /0.0 @:0 B@:0 P:0.0 A:24.5
Recv: T:19.1 /0.0 B:18.6 /0.0 T0:19.1 /0.0 @:0 B@:0 P:0.0 A:24.6
Recv: T:19.2 /0.0 B:18.8 /0.0 T0:19.2 /0.0 @:0 B@:0 P:0.0 A:24.4
Recv: T:19.2 /0.0 B:18.7 /0.0 T0:19.2 /0.0 @:0 B@:0 P:0.0 A:24.3
Recv: T:19.4 /0.0 B:18.9 /0.0 T0:19.4 /0.0 @:0 B@:0 P:0.0 A:24.6
Recv: T:19.3 /0.0 B:18.8 /0.0 T0:19.3 /0.0 @:0 B@:0 P:0.0 A:24.7
Recv: T:19.5 /0.0 B:18.7 /0.0 T0:19.5 /0.0 @:0 B@:0 P:0.0 A:24.5
Recv: T:19.1 /0.0 B:19.0 /0.0 T0:19.1 /0.0 @:0 B@:0 P:0.0 A:24.1
Recv: T:19.4 /0.0 B:18.8 /0.0 T0:19.4 /0.0 @:0 B@:0 P:0.0 A:24.5
Recv: T:19.2 /0.0 B:18.9 /0.0 T0:19.2 /0.0 @:0 B@:0 P:0.0 A:24.2
Recv: T:19.5 /0.0 B:18.9 /0.0 T0:19.5 /0.0 @:0 B@:0 P:0.0 A:24.6
Recv: T:20.1 /0.0 B:19.5 /0.0 T0:20.1 /0.0 @:0 B@:0 P:0.0 A:24.6
Recv: T:20.0 /0.0 B:19.4 /0.0 T0:20.0 /0.0 @:0 B@:0 P:0.0 A:24.5
Recv: T:19.6 /0.0 B:18.9 /0.0 T0:19.6 /0.0 @:0 B@:0 P:0.0 A:24.3
Recv: T:19.6 /0.0 B:18.8 /0.0 T0:19.6 /0.0 @:0 B@:0 P:0.0 A:24.4
Recv: T:19.7 /0.0 B:18.9 /0.0 T0:19.7 /0.0 @:0 B@:0 P:0.0 A:24.2
Recv: T:20.2 /0.0 B:19.6 /0.0 T0:20.2 /0.0 @:0 B@:0 P:0.0 A:24.9
Recv: T:19.9 /0.0 B:19.6 /0.0 T0:19.9 /0.0 @:0 B@:0 P:0.0 A:24.6
Recv: T:20.2 /0.0 B:19.5 /0.0 T0:20.2 /0.0 @:0 B@:0 P:0.0 A:25.1
Recv: T:20.0 /0.0 B:19.6 /0.0 T0:20.0 /0.0 @:0 B@:0 P:0.0 A:24.1
Recv: T:20.0 /0.0 B:19.6 /0.0 T0:20.0 /0.0 @:0 B@:0 P:0.0 A:24.9
Recv: T:20.2 /0.0 B:19.4 /0.0 T0:20.2 /0.0 @:0 B@:0 P:0.0 A:24.6
Recv: T:20.0 /0.0 B:19.5 /0.0 T0:20.0 /0.0 @:0 B@:0 P:0.0 A:24.6
Recv: T:20.0 /0.0 B:19.5 /0.0 T0:20.0 /0.0 @:0 B@:0 P:0.0 A:24.7
Recv: T:20.1 /0.0 B:19.2 /0.0 T0:20.1 /0.0 @:0 B@:0 P:0.0 A:24.8
Recv: T:19.7 /0.0 B:19.5 /0.0 T0:19.7 /0.0 @:0 B@:0 P:0.0 A:24.2
Recv: T:20.0 /0.0 B:19.3 /0.0 T0:20.0 /0.0 @:0 B@:0 P:0.0 A:24.6
Recv: T:20.0 /0.0 B:19.3 /0.0 T0:20.0 /0.0 @:0 B@:0 P:0.0 A:25.1
Recv: T:20.2 /0.0 B:19.5 /0.0 T0:20.2 /0.0 @:0 B@:0 P:0.0 A:24.9
Recv: T:19.9 /0.0 B:19.4 /0.0 T0:19.9 /0.0 @:0 B@:0 P:0.0 A:25.0
Recv: T:19.8 /0.0 B:19.3 /0.0 T0:19.8 /0.0 @:0 B@:0 P:0.0 A:25.0
Recv: T:19.9 /0.0 B:19.1 /0.0 T0:19.9 /0.0 @:0 B@:0 P:0.0 A:24.6
Recv: T:19.9 /0.0 B:19.5 /0.0 T0:19.9 /0.0 @:0 B@:0 P:0.0 A:25.1
Recv: T:19.5 /0.0 B:19.1 /0.0 T0:19.5 /0.0 @:0 B@:0 P:0.0 A:24.7
Recv: T:19.3 /0.0 B:18.9 /0.0 T0:19.3 /0.0 @:0 B@:0 P:0.0 A:24.8
Recv: T:19.6 /0.0 B:19.2 /0.0 T0:19.6 /0.0 @:0 B@:0 P:0.0 A:25.1
Recv: T:19.5 /0.0 B:19.1 /0.0 T0:19.5 /0.0 @:0 B@:0 P:0.0 A:24.4
Recv: T:19.6 /0.0 B:19.1 /0.0 T0:19.6 /0.0 @:0 B@:0 P:0.0 A:24.9
Recv: T:19.3 /0.0 B:19.0 /0.0 T0:19.3 /0.0 @:0 B@:0 P:0.0 A:25.0
Recv: T:19.3 /0.0 B:18.9 /0.0 T0:19.3 /0.0 @:0 B@:0 P:0.0 A:24.9
Changing monitoring state from "Operational" to "Starting"
Recv: ok
Changing monitoring state from "Starting" to "Printing"
Send: N1 M73 P0 R84*40
Recv: NORMAL MODE: Percent done: 0; print time remaining in mins: 84; Change in mins: -1
Recv: SILENT MODE: Percent done: -1; print time remaining in mins: -1; Change in mins: -1
Recv: ok
Send: N2 M73 Q0 S85*42
Recv: SILENT MODE: Percent done: 0; print time remaining in mins: 85; Change in mins: -1
Recv: ok
Send: N3 M201 X1000 Y1000 Z200 E5000*10
Recv: ok
Send: N4 M203 X200 Y200 Z12 E120*8
Recv: ok
Send: N5 M204 P1250 R1250 T1250*80
Recv: ok
Send: N6 M205 X8.00 Y8.00 Z0.40 E4.50*57
Recv: ok
Send: N7 M205 S0 T0*36
Recv: ok
Send: N8 M107*45
Recv: ok
Send: N9 M862.3 P "MK3SMMU2S"*57
Recv: ok
Send: N10 M862.1 P0.4*91
Recv: ok
Send: N11 M115 U3.10.0*97
Recv: ok
Send: N12 G90*35
Recv: ok
Send: N13 M83*42
Recv: ok
Send: N14 M104 S240*86
Recv: ok
Send: N15 M140 S85*108
Recv: ok
Send: Tx
Send: N16 M190 S85*98
Recv: T:19.5 /240.0 B:18.9 /85.0 T0:19.5 /240.0 @:127 B@:127 P:0.0 A:24.8
Recv: echo:busy: paused for user
Recv: T:20.2 /240.0 B:19.1 /85.0 T0:20.2 /240.0 @:127 B@:127 P:0.0 A:24.9
Recv: T:22.1 /240.0 B:19.5 /85.0 T0:22.1 /240.0 @:127 B@:127 P:0.0 A:25.2
Recv: T:25.7 /240.0 B:19.1 /85.0 T0:25.7 /240.0 @:127 B@:127 P:0.0 A:25.0
Recv: T:31.4 /240.0 B:19.4 /85.0 T0:31.4 /240.0 @:127 B@:127 P:0.0 A:25.4
Recv: T:37.2 /240.0 B:19.8 /85.0 T0:37.2 /240.0 @:127 B@:127 P:0.0 A:25.4
Recv: T:43.2 /240.0 B:20.4 /85.0 T0:43.2 /240.0 @:127 B@:127 P:0.0 A:25.6
Recv: mmu_get_response - begin move: T-code
Recv: MMU <= 'T0'
Recv: Unloading finished 2
Recv: T:50.2 /240.0 B:21.3 /85.0 T0:50.2 /240.0 @:127 B@:127 P:0.0 A:25.7
Recv: mmu_get_response - begin move: load
Recv: T:56.2 /240.0 B:22.0 /85.0 T0:56.2 /240.0 @:127 B@:127 P:0.0 A:25.6
Recv: T:62.5 /240.0 B:22.7 /85.0 T0:62.5 /240.0 @:127 B@:127 P:0.0 A:25.7
Recv: T:68.8 /240.0 B:23.7 /85.0 T0:68.8 /240.0 @:127 B@:127 P:0.0 A:25.6
Recv: T:74.8 /240.0 B:24.4 /85.0 T0:74.8 /240.0 @:127 B@:127 P:0.0 A:25.9
Recv: T:81.1 /240.0 B:25.4 /85.0 T0:81.1 /240.0 @:127 B@:127 P:0.0 A:25.8
Recv: T:87.0 /240.0 B:26.2 /85.0 T0:87.0 /240.0 @:127 B@:127 P:0.0 A:25.7
Recv: T:93.1 /240.0 B:27.0 /85.0 T0:93.1 /240.0 @:127 B@:127 P:0.0 A:26.2
Recv: T:98.8 /240.0 B:27.5 /85.0 T0:98.8 /240.0 @:127 B@:127 P:0.0 A:26.1
Recv: T:104.7 /240.0 B:28.4 /85.0 T0:104.7 /240.0 @:127 B@:127 P:0.0 A:26.1
Recv: T:110.4 /240.0 B:29.2 /85.0 T0:110.4 /240.0 @:127 B@:127 P:0.0 A:26.6
Recv: T:116.0 /240.0 B:29.8 /85.0 T0:116.0 /240.0 @:127 B@:127 P:0.0 A:26.1
Recv: T:121.6 /240.0 B:30.6 /85.0 T0:121.6 /240.0 @:127 B@:127 P:0.0 A:26.6
Recv: MMU => 'ok'
Recv: ok
Send: N17 M109 S240*88
Recv: T:127.2 /240.0 B:31.4 /85.0 T0:127.2 /240.0 @:127 B@:127 P:0.0 A:26.5
Recv: T:129.21 E:0 B:32.0
Recv: T:131.22 E:0 B:32.1
Recv: T:132.7 /240.0 B:32.2 /85.0 T0:132.7 /240.0 @:127 B@:127 P:0.0 A:26.3
Recv: T:134.06 E:0 B:32.4
Recv: T:136.79 E:0 B:32.9
Recv: T:138.1 /240.0 B:33.0 /85.0 T0:138.1 /240.0 @:127 B@:127 P:0.0 A:26.7
Recv: T:139.36 E:0 B:33.2
Recv: T:142.24 E:0 B:33.6
Recv: T:143.7 /240.0 B:33.9 /85.0 T0:143.7 /240.0 @:127 B@:127 P:0.0 A:26.6
Recv: T:144.48 E:0 B:34.3
Recv: T:147.16 E:0 B:34.6
Recv: T:149.1 /240.0 B:34.6 /85.0 T0:149.1 /240.0 @:127 B@:127 P:0.0 A:26.5
Recv: T:149.78 E:0 B:34.9
Recv: T:152.71 E:0 B:35.4
Recv: T:154.7 /240.0 B:35.4 /85.0 T0:154.7 /240.0 @:127 B@:127 P:0.0 A:26.8
Recv: T:155.43 E:0 B:35.6
Recv: T:158.02 E:0 B:36.0
Recv: T:159.8 /240.0 B:36.0 /85.0 T0:159.8 /240.0 @:127 B@:127 P:0.0 A:26.8
Recv: T:159.83 E:0 B:36.0
Recv: T:162.54 E:0 B:36.4
Recv: T:165.3 /240.0 B:36.9 /85.0 T0:165.3 /240.0 @:127 B@:127 P:0.0 A:26.9
Recv: T:165.35 E:0 B:36.9
Recv: T:167.87 E:0 B:37.2
Recv: T:170.5 /240.0 B:37.5 /85.0 T0:170.5 /240.0 @:127 B@:127 P:0.0 A:26.9
Recv: T:170.49 E:0 B:37.5
Recv: T:173.29 E:0 B:37.9
Recv: T:175.35 E:0 B:38.4
Recv: T:176.0 /240.0 B:38.3 /85.0 T0:176.0 /240.0 @:127 B@:127 P:0.0 A:26.9
Recv: T:178.06 E:0 B:38.6
Recv: T:180.54 E:0 B:39.0
Recv: T:181.3 /240.0 B:39.0 /85.0 T0:181.3 /240.0 @:127 B@:127 P:0.0 A:26.8
Recv: T:183.44 E:0 B:39.3
Recv: T:186.14 E:0 B:39.6
Recv: T:186.8 /240.0 B:39.7 /85.0 T0:186.8 /240.0 @:127 B@:127 P:0.0 A:27.0
Recv: T:188.04 E:0 B:39.9
Recv: T:190.49 E:0 B:40.2
Recv: T:191.8 /240.0 B:40.7 /85.0 T0:191.8 /240.0 @:127 B@:127 P:0.0 A:27.3
Recv: T:193.16 E:0 B:40.9
Recv: T:195.46 E:0 B:41.2
Recv: T:196.7 /240.0 B:41.6 /85.0 T0:196.7 /240.0 @:127 B@:127 P:0.0 A:27.3
Recv: T:198.03 E:0 B:41.8
Recv: T:200.31 E:0 B:42.4
Recv: T:201.7 /240.0 B:42.6 /85.0 T0:201.7 /240.0 @:127 B@:127 P:0.0 A:27.2
Recv: T:202.68 E:0 B:42.8
Recv: T:205.09 E:0 B:43.2
Recv: T:207.1 /240.0 B:43.4 /85.0 T0:207.1 /240.0 @:127 B@:127 P:0.0 A:27.9
Recv: T:207.86 E:0 B:43.8
Recv: T:210.47 E:0 B:44.2
Recv: T:212.2 /240.0 B:44.7 /85.0 T0:212.2 /240.0 @:119 B@:127 P:0.0 A:27.7
Recv: T:213.18 E:0 B:44.6
Recv: T:214.90 E:0 B:45.2
Recv: T:217.3 /240.0 B:45.8 /85.0 T0:217.3 /240.0 @:96 B@:127 P:0.0 A:27.4
Recv: T:217.34 E:0 B:45.8
Recv: T:219.53 E:0 B:46.1
Recv: T:222.3 /240.0 B:46.6 /85.0 T0:222.3 /240.0 @:73 B@:127 P:0.0 A:27.8
Recv: T:222.25 E:0 B:46.6
Recv: T:224.44 E:0 B:47.1
Recv: T:226.2 /240.0 B:47.5 /85.0 T0:226.2 /240.0 @:62 B@:127 P:0.0 A:27.4
Recv: T:226.19 E:0 B:47.5
Recv: T:227.63 E:0 B:48.1
Recv: T:229.06 E:0 B:48.5
Recv: T:229.6 /240.0 B:48.5 /85.0 T0:229.6 /240.0 @:53 B@:127 P:0.0 A:27.8
Recv: T:230.63 E:0 B:49.1
Recv: T:232.11 E:0 B:49.6
Recv: T:232.2 /240.0 B:49.4 /85.0 T0:232.2 /240.0 @:51 B@:127 P:0.0 A:28.2
Recv: T:232.97 E:0 B:50.1
Recv: T:233.91 E:0 B:50.2
Recv: T:234.5 /240.0 B:50.3 /85.0 T0:234.5 /240.0 @:48 B@:127 P:0.0 A:27.7
Recv: T:235.08 E:0 B:50.7
Recv: T:235.31 E:0 B:51.0
Recv: T:235.6 /240.0 B:51.2 /85.0 T0:235.6 /240.0 @:56 B@:127 P:0.0 A:27.9
Recv: T:235.94 E:0 B:51.4
Recv: T:236.48 E:0 B:51.9
Recv: T:237.3 /240.0 B:52.1 /85.0 T0:237.3 /240.0 @:52 B@:127 P:0.0 A:28.2
Recv: T:236.72 E:0 B:52.4
Recv: T:237.66 E:0 B:53.1
Recv: T:238.0 /240.0 B:53.2 /85.0 T0:238.0 /240.0 @:58 B@:127 P:0.0 A:28.2
Recv: T:238.36 E:0 B:53.6
Recv: T:238.98 E:0 B:54.1
Recv: T:239.1 /240.0 B:54.2 /85.0 T0:239.1 /240.0 @:56 B@:127 P:0.0 A:27.9
Recv: T:239.22 E:0 B:54.5
Recv: T:239.92 E:0 B:55.1
Recv: T:240.2 /240.0 B:55.0 /85.0 T0:240.2 /240.0 @:50 B@:127 P:0.0 A:28.3
Recv: T:240.31 E:0 B:55.3
Recv: T:241.15 E:0 B:55.4
Recv: T:241.4 /240.0 B:55.8 /85.0 T0:241.4 /240.0 @:42 B@:127 P:0.0 A:28.2
Recv: T:241.35 E:0 B:55.8
Recv: T:242.40 E:0 B:56.0
Recv: T:243.4 /240.0 B:56.3 /85.0 T0:243.4 /240.0 @:17 B@:127 P:0.0 A:28.6
Recv: T:243.44 E:0 B:56.3
Recv: T:243.85 E:0 B:56.6
Recv: T:243.75 E:0 B:57.1
Recv: T:244.2 /240.0 B:57.0 /85.0 T0:244.2 /240.0 @:14 B@:127 P:0.0 A:28.7
Recv: T:243.96 E:0 B:57.4
Recv: T:243.85 E:0 B:57.7
Recv: T:243.2 /240.0 B:57.6 /85.0 T0:243.2 /240.0 @:36 B@:127 P:0.0 A:28.4
Recv: T:244.06 E:0 B:58.0
Recv: T:243.96 E:0 B:58.3
Recv: T:243.8 /240.0 B:58.3 /85.0 T0:243.8 /240.0 @:29 B@:127 P:0.0 A:28.2
Recv: T:243.85 E:0 B:58.5
Recv: T:243.85 E:0 B:58.9
Recv: T:243.9 /240.0 B:59.0 /85.0 T0:243.9 /240.0 @:28 B@:127 P:0.0 A:28.7
Recv: T:243.44 E:0 B:59.2
Recv: T:243.33 E:0 B:59.5
Recv: T:242.8 /240.0 B:59.7 /85.0 T0:242.8 /240.0 @:44 B@:127 P:0.0 A:28.4
Recv: T:242.92 E:0 B:59.8
Recv: T:242.29 E:0 B:60.1
Recv: T:243.1 /240.0 B:60.3 /85.0 T0:243.1 /240.0 @:36 B@:127 P:0.0 A:28.6
Recv: T:242.29 E:0 B:60.2
Recv: T:243.33 E:0 B:60.6
Recv: T:242.8 /240.0 B:60.9 /85.0 T0:242.8 /240.0 @:39 B@:127 P:0.0 A:28.7
Recv: T:242.60 E:0 B:60.9
Recv: T:243.13 E:0 B:61.1
Recv: T:243.4 /240.0 B:61.5 /85.0 T0:243.4 /240.0 @:26 B@:127 P:0.0 A:28.6
Recv: T:243.13 E:0 B:61.5
Recv: T:243.13 E:0 B:61.7
Recv: T:243.1 /240.0 B:62.0 /85.0 T0:243.1 /240.0 @:29 B@:127 P:0.0 A:28.6
Recv: T:243.13 E:0 B:62.0
Recv: T:243.75 E:0 B:62.3
Recv: T:243.1 /240.0 B:62.6 /85.0 T0:243.1 /240.0 @:28 B@:127 P:0.0 A:28.7
Recv: T:243.13 E:0 B:62.6
Recv: T:243.13 E:0 B:63.0
Recv: T:242.8 /240.0 B:63.2 /85.0 T0:242.8 /240.0 @:31 B@:127 P:0.0 A:28.9
Recv: T:242.81 E:0 B:63.2
Recv: T:243.02 E:0 B:63.5
Recv: T:242.60 E:0 B:63.8
Recv: T:242.9 /240.0 B:63.9 /85.0 T0:242.9 /240.0 @:26 B@:127 P:0.0 A:28.9
Recv: T:243.02 E:0 B:64.1
Recv: T:242.19 E:0 B:64.3
Recv: T:242.2 /240.0 B:64.5 /85.0 T0:242.2 /240.0 @:35 B@:127 P:0.0 A:28.7
Recv: T:241.98 E:0 B:64.7
Recv: T:241.56 E:0 B:65.0
Recv: T:241.8 /240.0 B:65.1 /85.0 T0:241.8 /240.0 @:38 B@:127 P:0.0 A:29.1
Recv: T:242.19 E:0 B:65.3
Recv: T:242.19 E:0 B:65.6
Recv: T:241.4 /240.0 B:65.8 /85.0 T0:241.4 /240.0 @:42 B@:127 P:0.0 A:28.6
Recv: T:241.35 E:0 B:65.9
Recv: T:241.15 E:0 B:66.2
Recv: T:241.7 /240.0 B:66.2 /85.0 T0:241.7 /240.0 @:33 B@:127 P:0.0 A:29.3
Recv: T:241.77 E:0 B:66.3
Recv: T:241.67 E:0 B:66.5
Recv: T:241.1 /240.0 B:66.8 /85.0 T0:241.1 /240.0 @:39 B@:127 P:0.0 A:28.9
Recv: T:241.56 E:0 B:66.8
Recv: T:241.56 E:0 B:67.1
Recv: T:241.8 /240.0 B:67.3 /85.0 T0:241.8 /240.0 @:26 B@:127 P:0.0 A:28.9
Recv: T:241.77 E:0 B:67.3
Recv: T:241.56 E:0 B:67.6
Recv: T:241.5 /240.0 B:67.9 /85.0 T0:241.5 /240.0 @:29 B@:127 P:0.0 A:29.0
Recv: T:241.15 E:0 B:67.8
Recv: T:241.56 E:0 B:68.3
Recv: T:240.9 /240.0 B:68.5 /85.0 T0:240.9 /240.0 @:35 B@:127 P:0.0 A:29.0
Recv: T:240.94 E:0 B:68.5
Recv: T:241.35 E:0 B:68.7
Recv: T:241.5 /240.0 B:69.0 /85.0 T0:241.5 /240.0 @:24 B@:127 P:0.0 A:29.0
Recv: T:241.46 E:0 B:69.0
Recv: T:241.04 E:0 B:69.3
Recv: T:240.9 /240.0 B:69.5 /85.0 T0:240.9 /240.0 @:31 B@:127 P:0.0 A:29.1
Recv: T:240.94 E:0 B:69.5
Recv: T:241.25 E:0 B:69.6
Recv: T:240.63 E:0 B:69.9
Recv: T:240.8 /240.0 B:70.0 /85.0 T0:240.8 /240.0 @:31 B@:127 P:0.0 A:29.0
Recv: T:240.94 E:0 B:70.1
Recv: T:240.42 E:0 B:70.4
Recv: T:240.1 /240.0 B:70.6 /85.0 T0:240.1 /240.0 @:41 B@:127 P:0.0 A:29.4
Recv: T:240.63 E:0 B:70.7
Recv: T:240.83 E:0 B:70.9
Recv: T:240.6 /240.0 B:71.1 /85.0 T0:240.6 /240.0 @:31 B@:127 P:0.0 A:29.2
Recv: T:240.94 E:0 B:71.2
Recv: T:240.42 E:0 B:71.4
Recv: T:240.4 /240.0 B:71.5 /85.0 T0:240.4 /240.0 @:33 B@:127 P:0.0 A:29.1
Recv: T:240.31 E:0 B:71.7
Recv: T:240.31 E:0 B:71.9
Recv: T:240.0 /240.0 B:72.0 /85.0 T0:240.0 /240.0 @:38 B@:127 P:0.0 A:29.1
Recv: T:240.10 E:0 B:72.1
Recv: T:240.63 E:0 B:72.4
Recv: T:240.5 /240.0 B:72.5 /85.0 T0:240.5 /240.0 @:28 B@:127 P:0.0 A:29.1
Recv: T:240.21 E:0 B:72.6
Recv: T:240.52 E:0 B:72.8
Recv: T:240.5 /240.0 B:73.1 /85.0 T0:240.5 /240.0 @:28 B@:127 P:0.0 A:29.3
Recv: T:240.42 E:0 B:73.0
Recv: T:240.10 E:0 B:73.3
Recv: T:240.2 /240.0 B:73.5 /85.0 T0:240.2 /240.0 @:32 B@:127 P:0.0 A:29.3
Recv: T:240.21 E:0 B:73.5
Recv: T:240.31 E:0 B:73.8
Recv: T:240.2 /240.0 B:74.1 /85.0 T0:240.2 /240.0 @:32 B@:127 P:0.0 A:29.2
Recv: T:240.21 E:0 B:74.1
Recv: T:240.31 E:0 B:74.3
Recv: T:239.7 /240.0 B:74.5 /85.0 T0:239.7 /240.0 @:39 B@:127 P:0.0 A:29.8
Recv: T:239.69 E:0 B:74.5
Recv: T:239.92 E:0 B:74.8
Recv: T:239.77 E:0 B:74.9
Recv: T:239.7 /240.0 B:75.0 /85.0 T0:239.7 /240.0 @:38 B@:127 P:0.0 A:29.5
Recv: T:239.61 E:0 B:75.1
Recv: T:239.84 E:0 B:75.3
Recv: T:239.7 /240.0 B:75.5 /85.0 T0:239.7 /240.0 @:38 B@:127 P:0.0 A:29.3
Recv: T:239.45 E:0 B:75.6
Recv: T:240.42 E:0 B:75.8
Recv: T:240.5 /240.0 B:76.0 /85.0 T0:240.5 /240.0 @:23 B@:127 P:0.0 A:29.6
Recv: T:239.92 E:0 B:76.0
Recv: T:239.92 E:0 B:76.3
Recv: T:239.6 /240.0 B:76.4 /85.0 T0:239.6 /240.0 @:38 B@:127 P:0.0 A:29.3
Recv: T:240.42 E:0 B:76.5
Recv: T:240.31 E:0 B:76.8
Recv: T:239.6 /240.0 B:76.9 /85.0 T0:239.6 /240.0 @:38 B@:127 P:0.0 A:29.7
Recv: T:239.92 E:0 B:77.0
Recv: T:239.61 E:0 B:77.2
Recv: T:239.9 /240.0 B:77.3 /85.0 T0:239.9 /240.0 @:33 B@:127 P:0.0 A:29.4
Recv: T:240.21 E:0 B:77.4
Recv: T:240.00 E:0 B:77.6
Recv: T:240.3 /240.0 B:77.8 /85.0 T0:240.3 /240.0 @:27 B@:127 P:0.0 A:29.8
Recv: T:239.77 E:0 B:77.9
Recv: T:239.53 E:0 B:78.1
Recv: T:240.1 /240.0 B:78.2 /85.0 T0:240.1 /240.0 @:30 B@:127 P:0.0 A:29.5
Recv: T:239.84 E:0 B:78.3
Recv: T:239.61 E:0 B:78.5
Recv: T:239.8 /240.0 B:78.6 /85.0 T0:239.8 /240.0 @:34 B@:127 P:0.0 A:29.7
Recv: T:239.84 E:0 B:78.6
Recv: T:240.10 E:0 B:78.9
Recv: T:239.8 /240.0 B:79.1 /85.0 T0:239.8 /240.0 @:34 B@:127 P:0.0 A:29.5
Recv: T:239.84 E:0 B:79.1
Recv: T:240.42 E:0 B:79.3
Recv: T:239.1 /240.0 B:79.5 /85.0 T0:239.1 /240.0 @:45 B@:127 P:0.0 A:29.8
Recv: T:239.14 E:0 B:79.5
Recv: T:239.92 E:0 B:79.7
Recv: T:239.69 E:0 B:79.9
Recv: T:239.6 /240.0 B:80.1 /85.0 T0:239.6 /240.0 @:37 B@:127 P:0.0 A:29.8
Recv: T:239.45 E:0 B:80.3
Recv: T:240.10 E:0 B:80.4
Recv: T:239.7 /240.0 B:80.4 /85.0 T0:239.7 /240.0 @:36 B@:127 P:0.0 A:29.7
Recv: T:240.00 E:0 B:80.6
Recv: T:240.10 E:0 B:80.7
Recv: T:239.8 /240.0 B:80.8 /85.0 T0:239.8 /240.0 @:35 B@:100 P:0.0 A:29.6
Recv: T:239.84 E:0 B:80.9
Recv: T:239.84 E:0 B:81.2
Recv: T:240.4 /240.0 B:81.3 /85.0 T0:240.4 /240.0 @:24 B@:102 P:0.0 A:29.8
Recv: T:240.00 E:0 B:81.4
Recv: T:240.00 E:0 B:81.6
Recv: T:239.8 /240.0 B:81.7 /85.0 T0:239.8 /240.0 @:34 B@:100 P:0.0 A:29.7
Recv: T:240.10 E:0 B:81.7
Recv: T:240.21 E:0 B:82.0
Recv: T:240.0 /240.0 B:82.1 /85.0 T0:240.0 /240.0 @:32 B@:78 P:0.0 A:29.8
Recv: T:239.69 E:0 B:82.2
Recv: T:240.00 E:0 B:82.4
Recv: T:240.6 /240.0 B:82.5 /85.0 T0:240.6 /240.0 @:22 B@:69 P:0.0 A:29.6
Recv: T:240.21 E:0 B:82.6
Recv: T:240.00 E:0 B:82.8
Recv: T:239.8 /240.0 B:82.9 /85.0 T0:239.8 /240.0 @:35 B@:40 P:0.0 A:29.8
Recv: T:239.84 E:0 B:82.8
Recv: T:240.10 E:0 B:83.0
Recv: T:240.1 /240.0 B:83.1 /85.0 T0:240.1 /240.0 @:31 B@:52 P:0.0 A:29.8
Recv: T:240.10 E:0 B:83.1
Recv: T:240.10 E:0 B:83.3
Recv: T:239.8 /240.0 B:83.4 /85.0 T0:239.8 /240.0 @:35 B@:58 P:0.0 A:29.9
Recv: T:239.84 E:0 B:83.4
Recv: T:239.38 E:0 B:83.5
Recv: T:240.10 E:0 B:83.4
Recv: T:239.7 /240.0 B:83.5 /85.0 T0:239.7 /240.0 @:37 B@:63 P:0.0 A:30.0
Recv: T:239.84 E:0 B:83.6
Recv: T:239.2 /240.0 B:83.7 /85.0 T0:239.2 /240.0 @:44 B@:78 P:0.0 A:29.8
Recv: T:239.77 E:0 B:83.7
Recv: T:240.1 /240.0 B:83.8 /85.0 T0:240.1 /240.0 @:29 B@:71 P:0.0 A:29.7
Recv: T:240.00 E:0 B:83.8
Recv: T:239.77 E:0 B:83.9
Recv: T:239.7 /240.0 B:83.9 /85.0 T0:239.7 /240.0 @:36 B@:88 P:0.0 A:29.5
Recv: T:239.61 E:0 B:84.0
Recv: T:240.5 /240.0 B:84.0 /85.0 T0:240.5 /240.0 @:23 B@:91 P:0.0 A:29.9
Recv: T:239.92 E:0 B:84.0
Recv: T:240.10 E:0 B:84.1
Recv: T:240.0 /240.0 B:84.1 /85.0 T0:240.0 /240.0 @:32 B@:98 P:0.0 A:30.1
Recv: T:239.45 E:0 B:84.1
Recv: T:239.8 /240.0 B:84.3 /85.0 T0:239.8 /240.0 @:36 B@:78 P:0.0 A:30.1
Recv: T:240.10 E:0 B:84.2
Recv: T:240.00 E:0 B:84.3
Recv: T:239.6 /240.0 B:84.4 /85.0 T0:239.6 /240.0 @:39 B@:82 P:0.0 A:29.9
Recv: T:240.21 E:0 B:84.4
Recv: T:240.4 /240.0 B:84.5 /85.0 T0:240.4 /240.0 @:25 B@:72 P:0.0 A:29.8
Recv: T:240.42 E:0 B:84.5
Recv: T:240.5 /240.0 B:84.6 /85.0 T0:240.5 /240.0 @:24 B@:65 P:0.0 A:29.9
Recv: T:240.52 E:0 B:84.6
Recv: T:240.52 E:0 B:84.7
Recv: T:240.0 /240.0 B:84.9 /85.0 T0:240.0 /240.0 @:33 B@:38 P:0.0 A:30.0
Recv: T:240.00 E:0 B:84.9
Recv: T:240.10 E:0 B:84.9
Recv: T:239.77 E:0 B:84.9
Recv: T:239.8 /240.0 B:85.0 /85.0 T0:239.8 /240.0 @:37 B@:30 P:0.0 A:29.9
Recv: ok
Send: N18 G28 W*93
Recv: T:240.3 E:0 W:1
Recv: T:240.5 E:0 W:0
Recv: T:240.0 /240.0 B:85.1 /85.0 T0:240.0 /240.0 @:32 B@:29 P:0.0 A:30.0
Recv: ok
Send: N19 G80*41
Recv: tmc2130_home_enter(axes_mask=0x04)
Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x04
Recv: tmc2130_home_enter(axes_mask=0x01)
Recv: T:239.7 /240.0 B:85.2 /85.0 T0:239.7 /240.0 @:37 B@:32 P:0.0 A:30.0
Recv: 0 step=30 mscnt= 482
Recv: tmc2130_goto_step 0 29 2 1000
Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x01
Recv: tmc2130_home_enter(axes_mask=0x02)
Recv: T:240.1 /240.0 B:85.3 /85.0 T0:240.1 /240.0 @:30 B@:33 P:0.0 A:30.1
Recv: T:240.1 /240.0 B:85.3 /85.0 T0:240.1 /240.0 @:30 B@:44 P:0.0 A:29.8
Recv: 0 step=50 mscnt= 801
Recv: tmc2130_goto_step 1 49 2 1000
Recv: tmc2130_home_exit tmc2130_sg_homing_axes_mask=0x02
Recv: T:239.9 /240.0 B:85.4 /85.0 T0:239.9 /240.0 @:33 B@:42 P:0.0 A:30.1
Recv: T:239.5 /240.0 B:85.2 /85.0 T0:239.5 /240.0 @:41 B@:75 P:0.0 A:30.0
Recv: ok
Send: N20 G1 Y-3.0 F1000.0*26
Recv: T:240.4 /240.0 B:85.1 /85.0 T0:240.4 /240.0 @:25 B@:92 P:0.0 A:30.1
Recv: T:240.3 /240.0 B:85.1 /85.0 T0:240.3 /240.0 @:27 B@:101 P:0.0 A:29.7
Recv: T:240.1 /240.0 B:85.1 /85.0 T0:240.1 /240.0 @:31 B@:90 P:0.0 A:30.1
Recv: T:240.3 /240.0 B:85.1 /85.0 T0:240.3 /240.0 @:28 B@:93 P:0.0 A:30.1
I will try a few more and then enable simplyprint and test again
Could you please post the logs as file or at least put them into code braces:
It's quite a PITA to work with them this way... - Sorry -
Hi, noted for the next time.
So SimplyPrint may be the culprint
Is it possible to change the M117 message of SP to leave the [ and ] away?
I pay for simplyprint and talking them them at the moment. It does have an option to disable updating the screen so going to try this later after this first prints ok.
I'm from SimplyPrint - been chatting with Lee about the issue, and I can indeed see that it bugs the printer when we send the M117 command. As Lee mentions, there's an option to disable this feature (making us not send any commands to the printer during a print).
I do find it a bit odd that this started happening after the 1.7.3 OctoPrint update though, since no issues were being had before.
