Hi guys, I'm having a Communication error with the hotend around 190~200C and I appreciate your help.
Recv: T:209.82 /220.00 B:32.93 /0.00 @:64 B@:0
Recv: T:210.00 /220.00 B:33.02 /0.00 @:64 B@:0
No response from printer after 3 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Changing monitoring state from "Operational" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
octoprint (1).log (231.2 KB)
I have an Anet a8 Plus with SKR 1.l4 turbo and BLtouch. This error started yesterday for no reason.
Hello @Ulisses_Nogueira!
Could you share the serial.log.
The printer suddenly stops sending temperature reports:
2020-04-26 13:31:31,941 - Recv: T:200.36 /220.00 B:24.62 /0.00 @:64 B@:0
2020-04-26 13:31:33,941 - Recv: T:200.71 /220.00 B:24.62 /0.00 @:64 B@:0
2020-04-26 13:31:35,952 - Recv: T:201.25 /220.00 B:24.62 /0.00 @:64 B@:0
2020-04-26 13:33:06,010 - No response from printer after 3 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2020-04-26 13:33:06,038 - Changing monitoring state from "Operational" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
2020-04-26 13:33:06,055 - Connection closed, closing down monitor
Normally they come about every 2 seconds. There is a time gap of about 1 1/2 minute between the last report and the error message. In this situation, is there any specific message on the printer's display?
I don't have a display. All I use is the octoprint
