Communication Issues 1.11.0 Klipper
I was having communication problems with my nitehawk board after installing 1.11.0, so I reset Octoprint entirely from orbit after backing up the config and my printer.cfg. Now klipper won't connect at all after installing it.
2025-04-28 13:15:51,285 - octoprint.util.comm - ERROR - Something crashed inside the serial connection loop, please report this in OctoPrint's bug tracker:
  File "/home/voronpi/oprint/lib/python3.9/site-packages/octoprint/util/comm.py", line 3222, in _monitor
    self._perform_detection_step()
  File "/home/voronpi/oprint/lib/python3.9/site-packages/octoprint/util/comm.py", line 3515, in _perform_detection_step
    self._trigger_error(error_text, "autodetect")
  File "/home/voronpi/oprint/lib/python3.9/site-packages/octoprint/util/comm.py", line 4123, in _trigger_error
    self._callback.on_comm_error(
  File "/home/voronpi/oprint/lib/python3.9/site-packages/octoprint/printer/standard.py", line 1545, in on_comm_error
    self._error_info = ErrorInformation(
  File "/home/voronpi/oprint/lib/python3.9/site-packages/pydantic/main.py", line 253, in __init__
    validated_self = self.__pydantic_validator__.validate_python(data, self_instance=self)
pydantic_core._pydantic_core.ValidationError: 2 validation errors for ErrorInformation
faq
  Input should be a valid string [type=string_type, input_value=None, input_type=NoneType]
    For further information visit https://errors.pydantic.dev/2.11/v/string_type
logs
  Input should be a valid list [type=list_type, input_value=None, input_type=NoneType]
    For further information visit https://errors.pydantic.dev/2.11/v/list_type
Reinstalled 1.11.0
Yes
octoprint-systeminfo-20250428133637.zip (74.7 KB)
Octoprint 1.11.0, Voron 2.4 on a RPi4, fresh Klipper, Linux Mint Cinnamon, Firefox
Hello @invaderrizz !
What OctoPrint/Klipper setup do you use?
Probably need to add the virtual serial port to OctoPrint and use it.
https://www.klipper3d.org/OctoPrint.html?h=octoprint#configuring-octoprint-to-use-klipper
