Attempted to print a calibration tower and it failed with a communication timeout error. Problem occurred just after updating to OctoPrint 1.3.9. Log seems to indicate it could be related to the Exclude Region plug-in.
Can you provide any insight as to what may be causing this? Thanks!
Rebooted OctoPrint.
OctoPrint version: 1.3.9
OctoPi version: 0.15.1
Printer: Prusa i3 MK3
Printer Firmware: 3.3.1-845
Pi: Raspberry Pi 3B+
Camera: Raspberry Pi Camera Module v2
OctoPrint Log (last few lines before failure):
2018-07-26 20:41:07,522 - octoprint.plugins.excluderegion - INFO - Event received: event=ZChange payload={'new': 92.6, 'old': 93.0}
2018-07-26 20:41:14,460 - octoprint.util.comm - INFO - Got a resend request from the printer: requested line = 8759, current line = 8766
| Last lines in terminal:
| Recv: ok
| Send: N8759 G1 E0.80000 F2100.00000*35
| Recv: ok
| Send: N8760 M204 S800*87
| Recv: ok
| Send: N8761 G1 F900*79
| Recv: ok
| Send: N8762 G1 X137.275 Y117.275 E0.00609*84
| Send: N8763 G1 X112.725 Y117.275 E0.83099*86
| Recv: echo:busy: processing
| Recv: ok
| Send: N8764 M105*26
| Recv: Full RX Buffer
| Recv: tmc2130_goto_step 3 28 2 1000
| Recv: ok
| Send: N8765 G1 X112.725 Y92.725 E0.83099*108
| Recv: Error:Line Number is not Last Line Number+1, Last Line: 8758
| Recv: Resend: 8759
2018-07-26 20:41:14,500 - octoprint.util.comm - INFO - Ignoring resend request for line 8759, that still originates from lines we sent before we got the first resend request
2018-07-26 20:41:14,597 - octoprint.plugins.excluderegion - WARNING - Encountered recovery without a corresponding retraction: G1 E-0.04000 F2100.00000
2018-07-26 20:41:14,598 - octoprint.plugins.excluderegion - INFO - recovery: excluding=False, originalCmd=G1 E-0.04000 F2100.00000, returnCommands=[u'G1 E-0.04000 F2100.00000']
2018-07-26 20:41:14,615 - octoprint.plugins.excluderegion - INFO - Event received: event=ZChange payload={'new': 93.2, 'old': 92.6}
2018-07-26 20:41:14,621 - octoprint.plugins.excluderegion - INFO - Event received: event=Dwelling payload=None
2018-07-26 20:41:14,635 - octoprint.plugins.excluderegion - INFO - Event received: event=ZChange payload={'new': 92.8, 'old': 93.2}
2018-07-26 20:41:18,694 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-26 20:41:21,528 - octoprint.plugins.excluderegion - WARNING - Encountered recovery without a corresponding retraction: G1 E0.80000 F2100.00000
2018-07-26 20:41:21,530 - octoprint.plugins.excluderegion - INFO - recovery: excluding=False, originalCmd=G1 E0.80000 F2100.00000, returnCommands=[u'G1 E0.80000 F2100.00000']
2018-07-26 20:41:21,665 - octoprint.plugins.excluderegion - WARNING - Encountered recovery without a corresponding retraction: G1 E-0.04000 F2100.00000
2018-07-26 20:41:21,666 - octoprint.plugins.excluderegion - INFO - recovery: excluding=False, originalCmd=G1 E-0.04000 F2100.00000, returnCommands=[u'G1 E-0.04000 F2100.00000']
2018-07-26 20:41:21,687 - octoprint.plugins.excluderegion - INFO - Event received: event=ZChange payload={'new': 93.4, 'old': 92.8}
2018-07-26 20:41:21,692 - octoprint.plugins.excluderegion - INFO - Event received: event=Dwelling payload=None
2018-07-26 20:41:21,703 - octoprint.plugins.excluderegion - WARNING - Encountered recovery without a corresponding retraction: G1 E0.80000 F2100.00000
2018-07-26 20:41:21,705 - octoprint.plugins.excluderegion - INFO - recovery: excluding=False, originalCmd=G1 E0.80000 F2100.00000, returnCommands=[u'G1 E0.80000 F2100.00000']
2018-07-26 20:41:21,713 - octoprint.plugins.excluderegion - INFO - Event received: event=ZChange payload={'new': 93.0, 'old': 93.4}
2018-07-26 20:41:28,607 - octoprint.plugins.excluderegion - WARNING - Encountered recovery without a corresponding retraction: G1 E-0.04000 F2100.00000
2018-07-26 20:41:28,608 - octoprint.plugins.excluderegion - INFO - recovery: excluding=False, originalCmd=G1 E-0.04000 F2100.00000, returnCommands=[u'G1 E-0.04000 F2100.00000']
2018-07-26 20:41:28,631 - octoprint.plugins.excluderegion - INFO - Event received: event=Dwelling payload=None
2018-07-26 20:41:28,636 - octoprint.plugins.excluderegion - INFO - Event received: event=ZChange payload={'new': 93.6, 'old': 93.0}
2018-07-26 20:41:28,647 - octoprint.plugins.excluderegion - WARNING - Encountered recovery without a corresponding retraction: G1 E0.80000 F2100.00000
2018-07-26 20:41:28,648 - octoprint.plugins.excluderegion - INFO - recovery: excluding=False, originalCmd=G1 E0.80000 F2100.00000, returnCommands=[u'G1 E0.80000 F2100.00000']
2018-07-26 20:41:28,661 - octoprint.plugins.excluderegion - INFO - Event received: event=ZChange payload={'new': 93.2, 'old': 93.6}
2018-07-26 20:41:35,705 - octoprint.plugins.excluderegion - WARNING - Encountered recovery without a corresponding retraction: G1 E-0.04000 F2100.00000
2018-07-26 20:41:35,707 - octoprint.plugins.excluderegion - INFO - recovery: excluding=False, originalCmd=G1 E-0.04000 F2100.00000, returnCommands=[u'G1 E-0.04000 F2100.00000']
2018-07-26 20:41:35,735 - octoprint.plugins.excluderegion - INFO - Event received: event=Dwelling payload=None
2018-07-26 20:41:35,752 - octoprint.plugins.excluderegion - WARNING - Encountered recovery without a corresponding retraction: G1 E0.80000 F2100.00000
2018-07-26 20:41:35,754 - octoprint.plugins.excluderegion - INFO - recovery: excluding=False, originalCmd=G1 E0.80000 F2100.00000, returnCommands=[u'G1 E0.80000 F2100.00000']
2018-07-26 20:41:35,758 - octoprint.plugins.excluderegion - INFO - Event received: event=ZChange payload={'new': 93.8, 'old': 93.2}
2018-07-26 20:41:35,771 - octoprint.plugins.excluderegion - INFO - Event received: event=ZChange payload={'new': 93.4, 'old': 93.8}
2018-07-26 20:41:53,810 - octoprint.util.comm - INFO - No response from printer after 6 consecutive communication timeouts, considering it dead.
2018-07-26 20:41:53,833 - octoprint.plugins.excluderegion - INFO - Event received: event=Error payload={'reason': 'timeout', 'error': 'Too many consecutive timeouts, printer still connected and alive?'}
2018-07-26 20:41:53,834 - octoprint.plugins.excluderegion - INFO - Printing stopped
2018-07-26 20:41:53,845 - octoprint.plugins.excluderegion - INFO - Event received: event=UpdatedFiles payload={'type': 'gcode'}
2018-07-26 20:41:53,857 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
2018-07-26 20:41:53,887 - octoprint.plugins.excluderegion - INFO - Event received: event=Disconnected payload=None
2018-07-26 20:41:53,894 - octoprint.plugins.excluderegion - INFO - Event received: event=PrinterStateChanged payload={'state_string': 'Offline', 'state_id': 'OFFLINE'}
2018-07-26 20:41:53,929 - octoprint.plugins.excluderegion - INFO - Event received: event=MetadataStatisticsUpdated payload={'path': u'pla-mk-3-ecor-tower.gcode', 'storage': 'local'}
2018-07-26 20:41:56,445 - octoprint.plugins.excluderegion - INFO - Event received: event=PrintFailed payload={'origin': 'local', 'name': u'pla-mk-3-ecor-tower.gcode', 'file': u'/home/pi/.octoprint/uploads/pla-mk-3-ecor-tower.gcode', 'time': 3557.72283411026, 'path': u'pla-mk-3-ecor-tower.gcode', 'size': 245309L, 'filename': u'pla-mk-3-ecor-tower.gcode'}
2018-07-26 20:41:56,446 - octoprint.plugins.excluderegion - INFO - Printing stopped
Serial Log (last few lines before failure):
2018-07-26 20:41:35,694 - Send: N8822 G1 X137.275 Y117.275 E-0.04401*124
2018-07-26 20:41:35,699 - Send: N8823 G1 F8160*112
2018-07-26 20:41:35,700 - Recv: ok
2018-07-26 20:41:35,714 - Recv: ok
2018-07-26 20:41:35,722 - Recv: ok
2018-07-26 20:41:35,723 - Send: N8824 G1 X134.346 Y117.275 E-0.71599*122
2018-07-26 20:41:35,737 - Recv: ok
2018-07-26 20:41:35,734 - Send: N8825 G1 E-0.04000 F2100.00000*6
2018-07-26 20:41:35,743 - Recv: ok
2018-07-26 20:41:35,747 - Send: N8826 G1 Z93.800 F10200.000*49
2018-07-26 20:41:35,748 - Recv: ok
2018-07-26 20:41:35,753 - Send: N8827 G4 S0*91
2018-07-26 20:41:35,761 - Send: TMC_SET_STEP_E932
2018-07-26 20:41:35,764 - Send: N8828 G1 Z93.400 F10200.000*51
2018-07-26 20:41:35,767 - Send: N8829 G1 E0.80000 F2100.00000*43
2018-07-26 20:41:35,769 - Send: N8830 M204 S800*93
2018-07-26 20:41:35,779 - Recv: Full RX Buffer
2018-07-26 20:41:53,812 - No response from printer after 6 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2018-07-26 20:41:53,855 - Changing monitoring state from "Printing" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
2018-07-26 20:41:53,872 - Connection closed, closing down monitor
) The octoprint and serial logs are attached. Both were recorded in safe mode.
I'm sorry... for some reason I saw this
