If i change the communication timeout, i cant save the config.
Saving does work if i change the value.
Problem since i updated today. Same on 5 different Printer, after update.
Hope someone can fix it in the next Version, need to change the value, Thanks.
You should still be able to edit it manually in ~/.octoprint/config.yaml or via something like ~/oprint/bin/octoprint config set --float "serial.timeout.communication" 40 (adjust 40 to your desired value).
That made me chuckle. Did you know that OctoPrint is mostly done by one person? Hi. I'm that "someone".
Hi , no i did not know that fact, big respect what you did so far. I really like it.
