If I start my print it only "primes" the nozzle and then disconnects when sliced with prusaslicer. If I slice using cura it works fine.
- Changed some settings in prusaslicer.
- Tried exporting directly from prusaslicer and tried it with just uploading.
Complete Logs
Serial.log:
2021-04-24 19:20:44,598 - Changing monitoring state from "Operational" to "Starting"
2021-04-24 19:20:44,698 - Send: N0 M110 N0*125
2021-04-24 19:20:44,717 - Recv: ok
2021-04-24 19:20:44,719 - Changing monitoring state from "Starting" to "Printing"
2021-04-24 19:20:44,723 - Send: N1 M107*36
2021-04-24 19:20:44,729 - Recv: ok 1
2021-04-24 19:20:44,731 - Send: N2 M117 Initializing*43
2021-04-24 19:20:44,745 - Recv: ok 2
2021-04-24 19:20:44,751 - Send: N3 M83*27
2021-04-24 19:20:44,769 - Recv: ok 3
2021-04-24 19:20:44,770 - Send: N4 M107*33
2021-04-24 19:20:44,774 - Recv: ok 4
2021-04-24 19:20:44,775 - Send: N5 G28*22
2021-04-24 19:20:44,782 - Recv: ok 5
2021-04-24 19:20:44,783 - Recv: busy:processing
2021-04-24 19:20:44,783 - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2021-04-24 19:20:44,784 - Send: N6 M140 S80*91
2021-04-24 19:20:45,842 - Recv: SelectExtruder:0
2021-04-24 19:20:45,849 - Recv: FlowMultiply:100
2021-04-24 19:20:45,851 - Recv: X:0.00 Y:0.00 Z:217.175 E:40.0000
2021-04-24 19:20:45,852 - Recv: ok 6
2021-04-24 19:20:45,855 - Send: N7 M113 S2*102
2021-04-24 19:20:45,862 - Recv: ok 7
2021-04-24 19:20:45,864 - Send: N8 M105*47
2021-04-24 19:20:45,866 - Recv: Unknown command:N7 M113 S2
2021-04-24 19:20:45,870 - Recv: ok 8
2021-04-24 19:20:45,872 - Send: N9 M190 S80*89
2021-04-24 19:20:45,875 - Recv: T:239.74 /240 B:80.00 /80 B@:0 @:175
2021-04-24 19:20:45,877 - Recv: ok 9
2021-04-24 19:20:45,879 - Send: N10 M104 S240*82
2021-04-24 19:20:45,902 - Recv: ok 10
2021-04-24 19:20:45,904 - Recv: TargetExtr0:240
2021-04-24 19:20:45,907 - Send: N11 M109 S240*94
2021-04-24 19:20:45,914 - Recv: ok 11
2021-04-24 19:20:45,917 - Send: N12 G92 E0*116
2021-04-24 19:20:45,917 - Recv: TargetExtr0:240
2021-04-24 19:20:45,923 - Recv: ok 12
2021-04-24 19:20:45,925 - Send: N13 G1 X-98 Y0 Z0.2 F4000*51
2021-04-24 19:20:45,931 - Recv: ok 13
2021-04-24 19:20:45,933 - Send: N14 G3 X0 Y-98 I98 Z0.2 E40 F400*15
2021-04-24 19:20:46,967 - Recv: ok 14
2021-04-24 19:20:46,970 - Send: N15 G0 Z1*86
2021-04-24 19:20:49,974 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-04-24 19:20:49,980 - Send: N16 M105*16
2021-04-24 19:20:52,979 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-04-24 19:20:52,984 - Send: N17 M105*17
2021-04-24 19:20:55,983 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-04-24 19:20:55,989 - Send: N18 M105*30
2021-04-24 19:20:58,988 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-04-24 19:20:58,993 - Send: N19 M105*31
2021-04-24 19:21:01,993 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-04-24 19:21:01,998 - Send: N20 M105*21
2021-04-24 19:21:04,997 - No response from printer after 6 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-04-24 19:21:05,062 - Changing monitoring state from "Printing" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
2021-04-24 19:21:05,070 - Connection closed, closing down monitor
Octoprint.log:
2021-04-24 19:20:44,481 - octoprint.filemanager.analysis - INFO - Starting analysis of local:shifter_unit_top_PETG_50m.gcode
2021-04-24 19:20:44,482 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python3 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 /home/pi/.octoprint/uploads/shifter_unit_top_PETG_50m.gcode
2021-04-24 19:20:44,549 - octoprint.printer.standard.job - INFO - Print job selected - origin: local, path: shifter_unit_top_PETG_50m.gcode, owner: _api, user: _api
2021-04-24 19:20:44,598 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Starting"
2021-04-24 19:20:44,642 - octoprint.printer.standard.job - INFO - Print job started - origin: local, path: shifter_unit_top_PETG_50m.gcode, owner: _api, user: _api
2021-04-24 19:20:44,697 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-04-24 19:20:44,719 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2021-04-24 19:20:44,783 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2021-04-24 19:20:44,910 - octoprint.plugins.tracking - INFO - Sent tracking event print_started, payload: {'origin': 'local', 'file': '3ce033a2b182a1213ee2793ae58a179d9d31d500'}
2021-04-24 19:20:45,857 - octoprint.util.comm - INFO - Telling the printer to set the busy interval to our "communicationBusy" timeout - 1s = 2s
2021-04-24 19:20:49,974 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-04-24 19:20:52,979 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-04-24 19:20:55,982 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-04-24 19:20:58,987 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-04-24 19:21:01,992 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-04-24 19:21:04,997 - octoprint.util.comm - INFO - No response from printer after 6 consecutive communication timeouts, considering it dead.
2021-04-24 19:21:05,062 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
- Octoprint version 1.5.3
- OctoPi version 0.18.0
- Raspberry Pi 4B 2GB
- FLSun Q5 (MKS 2.5)
- Google Chrome
- Windows 10
- Prusaslicer
- Standard PETG profile on prusaslicer
