Hello,
since the last update of OctoPrint (v1.3.8), it have a lot of issues with communication and connection with my printer.
When I press the "Connect" button with the usual settings (serial port : /dev/ttyUSB0 and baudrate : 250000), I have a communication timeout :
serial.log
Connecting to: /dev/ttyUSB0
Changing monitoring state from "Offline" to "Opening serial port"
Connected to: Serial<id=0x6bc80bd0, open=True>(port='/dev/ttyUSB0', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Changing monitoring state from "Opening serial port" to "Connecting"
Send: N0 M110 N0*125
Recv: start
Recv: echo:Marlin 1.1.0-RC6
Recv: echo: Last Updated: 2016-04-24 12:00 | Author: Dagoma.Fr
Recv: Compiled: Sep 12 2016
Recv: echo: Free Memory: 3545 PlannerBufferBytes: 1232
Recv: echo:V23 stored settings retrieved (396 bytes)
Recv: echo:Steps per unit:
Recv: echo: M92 X80.00 Y80.00 Z2560.00 E98.00
Recv: echo:Maximum feedrates (mm/s):
Recv: echo: M203 X500.00 Y500.00 Z4.00 E25.00
Recv: echo:Maximum Acceleration (mm/s2):
Recv: echo: M201 X9000 Y3000 Z100 E10000
Recv: echo:Accelerations: P=printing, R=retract and T=travel
Recv: echo: M204 P3000.00 R3000.00 T3000.00
Recv: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
Recv: echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
Recv: echo:Home offset (mm):
Recv: echo: M206 X0.00 Y0.00 Z0.00
Recv: echo:PID settings:
Recv: echo: M301 P32.48 I6.40 D41.25 C100.00 L20
Recv: echo:Filament settings: Disabled
Recv: echo: M200 D3.00
Recv: echo: M200 D0
Recv: echo:Z-Probe Offset (mm):
Recv: echo: M851 Z-1.00
Recv: echo:SD init fail
Recv: OK
There was a timeout while trying to connect to the printer
Changing monitoring state from "Connecting" to "Offline"
I succeed in connecting by changing the serial port and baudrate settings by AUTO, and I have this in return :
serial.log
Serial port list: ['/dev/ttyUSB0']
Connected to: Serial<id=0x6ba795f0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Starting baud rate detection
Trying baudrate: 250000
Recv: start
Changing monitoring state from "Detecting baudrate" to "Operational"
Send: N1 M105*38
Recv: echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (��6J[[iWI��\x16�K\x02\x02j%��\x02�\x1d& \x13\x13$�0.00 B20000 X20.00 Z0.40 E5.00
Recv: echo: M200 D0
Recv: OK T:0.0 /0.0 @:0
Then I have a lot of
in the terminal tab.
I tried to set a temperature, but the temperature graph is not up-to-date and have a couple of minutes of latency. If I try to launch a printing job, my printer just don't do anything and stay still on my desk (poor printer!)
I tried to send commands directly in the terminal tab, but nothing was sent to the printer. After too many timeouts, they were disconnected.
My printer is alive, I launched a printing job by hand and everything was OK.
I have no clue of what's going on. Everything was great before the last update.
Starring :
- Octoprint v1.3.8 as "the software"
- Octopi v0.14.0 as "the distro"
- Raspberry Pi3 B as "the hardware"
Dagoma DiscoEasy200 as "the printer"
Unfortunatly, David Hasselhoff wasn't free today...
