Config file Cam new in 0.17?
New function Config file for each camera.
I find this in the development log of octopi.
Did somebody has information about this Config files?
It is a copy of the normal?
Example?
Camera model more then one
What is the problem? Pi 4 OctoPi 0.17
Config file need
I have already started to rewrite the code of the first Pi4 build, because the device numbers always change.
The ability to create configuration for each camera would be great.
I understand correctly that this post is already implemented in OctoPi 17.
I hope that's what you are searching for :slight_smile:
