raspi cam v1.2 with ir
no matter what I change is the config file the log output stays at the default resolution fps and camera selection
I have used 3 different pi's reinstalled octo print on all of them tried changing it using notepad++ as awell as the cmd line also have tried to focus the camera does not help
Logs
webcam log
Starting up webcamDaemon...
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Dec 2 12:56:14 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
Goodbye...
i: Frames Per Second.: 10
i: Format............: JPEG
UVCIOC_CTRL_MAP - Error at LED1 Mode: Inappropriate ioctl for device (25) UVCIOC_CTRL_MAP - Error at LED1 Frequency: Inappropriate ioctl for device (25) UVCIOC_CTRL_MAP - Error at Disable video processing: Inappropriate ioctl for device (25)
o: HTTP Listen Address..: 127.0.0.1
config file
Windows users: To edit this file use Notepad++, VSCode, Atom or SublimeText.
Do not use Notepad or WordPad.
MacOSX users: If you use Textedit to edit this file make sure to use
"plain text format" and "disable smart quotes" in "Textedit > Preferences"
Configure which camera to use
Available options are:
- auto: tries first usb webcam, if that's not available tries raspi cam
- usb: only tries usb webcam
- raspi: only tries raspi cam
Defaults to auto
camera="raspi"
Additional options to supply to MJPG Streamer for the USB camera
See https://faq.octoprint.org/mjpg-streamer-config for available options
Defaults to a resolution of 640x480 px and a framerate of 10 fps
camera_usb_options="-r 1280x720 -f 15"
additional_brokenfps_usb_devices=("aabb:ccdd" "aabb:eeff")
If this fixes your problem, please report it back so we can include the device
out of the box: Issues Β· guysoft/OctoPi Β· GitHub
#additional_brokenfps_usb_devices=()
Additional options to supply to MJPG Streamer for the RasPi Cam
See https://faq.octoprint.org/mjpg-streamer-config for available options.
NOTE: Newer raspi cam modules are reporting as usb devices causing these
options to be ignored. Set camera="raspi" to avoid these issues.
Defaults to 10fps
camera_raspi_options="-x 1280 -y 720 -fps 20"
Configuration of camera HTTP output
Usually you should NOT need to change this at all! Only touch if you
know what you are doing and what the parameters mean.
Below settings are used in the mjpg-streamer call like this:
-o "output_http.so -w $camera_http_webroot $camera_http_options"
Current working directory is the mjpg-streamer base directory.
#camera_http_webroot="./www-octopi"
#camera_http_options="-n"
EXPERIMENTAL
Support for different streamer types.
Available options:
mjpeg [default] - stable MJPG-streamer
hls - experimental FFMPEG HLS streamer
#camera_streamer=mjpeg
Additional information about your setup (OctoPrint version, OctoPi version, ...) newest version of octoprint running on raspi 3b+ hope yall can help
