after many and many check i started octopi manually and i found an error starting due to corrupted config.yaml file.
i don't have a recent backup.
the config.yaml is really corrupted with strange characters.
i created a new file copied from github
now octoprint starts but i cannot login with my user and password. these are corrects.
what do you suggest ?
how can i get a working file ? how can i setup/force the user ?
The config.yaml file is paired up with a users.yaml file, so you can't just replace one without replacing the other, the logins will not work as the salts don't line up.
I have a USB SD card reader/writer. I plug it into my desktop when I want to create a new SD card image and I plug it into my RPi and use rpi-clone to make a backup copy.
If you don't have anything installed on the Pi outside of OctoPrint, creating a backup inside OctoPrint and downloading that should be enough in my opinion.
