Is there a setup guide or any instructions on how to connect a bl or cr touch directly to a pi 4 running octoprint, including powerering it?
This is for a setup using an ender 5 where I can't open the printer up and make changes, or change the firmware from stock, but I can bolt things on to the outside.
Everything needs to be able to be done without opening the case on the ender 5, is this even possible?
