Connecting Octo Print to a secures WPA2 network
Trying to connect to a network on WPA2 which requires SSID, login name and password
Not sure where to start
Afternoon all
I'm a technician at a college and have been asked to make a 3D printer remotely available to students without allowing them access to the secure storage where the printers are kept, the trouble is that we are on a secure WPA2 network which needs an SSID, login, and password. I did try simply adding "login="login name" " to the network configuration file with no nesult and was wondering if what I'm attempting could even be done
Thanks for any help
You might need a few more details about exactly what type of authentication it is, but as an example WPA2 enterprise configuration, I found this one on the web:
network={
ssid="college SSID"
# authentication method
key_mgmt=WPA-EAP
eap=PEAP
phase2="auth=MSCHAPV2"
# username and password
identity="insert username"
password="insert password"
It is not necessarily OctoPi specific configuration needed, you could broaden your search by just looking for generic Raspberry Pi configuration for your network type.
