Can't connect octoprint to my eduroam wifi.
Tried putting in the WPA-Enterprise specific lines in wpa-supplicant. Tried making ethernet static ip. Tried editing
I currently have a printer and an instance of octoprint running well on my school's wifi, eduroam. The wifi specifications are seen below.
I am attempting to setup another RPi for my second printer. I initially thought just editing the relevant conf files on my new SD card to match my old working one would work but it didn't. I then tried putting my old working SD card into my new Pi and it works so I know it's not a broken Pi. So now I'm confused what I'm missing on my new SD Card.
This is the order I have changed things on a fresh OctoPi install. (I didn't change anything in windows before these steps)
I SSHed into the new Pi using an ethernet cable and changed the locale to "en_US.UTF-8 UTF-8" and the timezone and wifi country to US.
I went into wpa-supplicant, deleted everything in it and added the lines below. (The username and password are correct in the real thing)
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=US
network={
ssid="eduroam"
proto=RSN
key_mgmt=WPA-EAP
identity="my school username"
password="my school password"
phase1="peaplabel=0"
phase2="auth=MSCHAPV2"
- I went into dhcpcd.conf and uncommented these lines
profile static_eth0
static ip_address=192.168.1.23/24
- I shutdown OctoPi and unplugged the ethernet and power. Then I powered up the raspberry pi again and waited a few minutes. Plugged my ethernet back in and it still hadn't connected to the wifi.
I've also tried a using a bunch of different lines for wpa-supplicant, interfaces, and dhcpcd suggested to work for eduroam on the internet. This is one of the most comprehensive ones I tried (Reddit). Also I know I can just clone the SD card to my new one but I would like to figure out how to do it so I can connect non octoprint RPi instances to the wifi as well. Lastly I have a Win32DiskImager cloning file for my old working SD card in my google drive if people are curious enough. Thank you all!
