I have a problem with Octoprint:
As soon as I start printing with the "print" button, the printer disconnects, or its relay is triggered to open. Any idea what this can be?
Rebooted the system, tried different models.
I can't try, I can't control the relay to power the printer in safe mode.
octoprint-systeminfo-20221218132930.zip (83.6 KB)
Octoprint 1.8.4 / Ender 3 / Raspberry 4 / Relay to switch printer power on and off at GPIO27.
Log when "print" is pressed:
Summary
Changing monitoring state from "Offline" to "Detecting serial connection".
Performing autodetection with 1 port/baudrate candidates: /dev/ttyUSB0@115200
Trying port /dev/ttyUSB0, baudrate 115200
Connecting to port /dev/ttyUSB0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0xa7bcc7f0, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Recv: start
Changing monitoring state from "Detecting serial connection" to "Operational
Send: N0 M110 N0125
Recv: echo: External Reset
Recv: Marlin 1.1.6
Recv:
Recv: echo: Last Updated: 2018-11-28 | Author: (Ender-3)
Recv: echo:Compiled: Jan 27 2019
Recv: echo: Free Memory: 9994 PlannerBufferBytes: 1232
Recv: echo:TF init fail
Recv: ok
Send: N1 M11539
Recv: FIRMWARE_NAME:Marlin Creality 3D SOURCE_CODE_URL:GitHub - MarlinFirmware/Marlin: Marlin is an optimized firmware for RepRap 3D printers based on the Arduino platform. | Many commercial 3D printers come with Marlin installed. Check with your vendor if you need source code for your specific machine. PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender-3 EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
Recv: Cap:EEPROM:1
Recv: Cap:AUTOREPORT_TEMP:1
Recv: Cap:PROGRESS:0
Recv: Cap:PRINT_JOB:1
Recv: Cap:AUTOLEVEL:0
Recv: Cap:Z_PROBE:0
Recv: Cap:LEVELING_DATA:0
Recv: Cap:SOFTWARE_POWER:0
Recv: Cap:TOGGLE_LIGHTS:0
Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
Recv: Cap:EMERGENCY_PARSER:0
Recv: ok
Send: M21
Recv: ok
Send: M105
Recv: ok T:19.34 /0.00 B:21.02 /0.00 @:0 B@:0
Send: M155 S2
Recv: ok
Recv: T:19.34 /0.00 B:20.86 /0.00 @:0 B@:0
Recv: T:19.34 /0.00 B:21.09 /0.00 @:0 B@:0
Recv: T:19.34 /0.00 B:20.98 /0.00 @:0 B@:0
Recv: T:19.34 /0.00 B:21.02 /0.00 @:0 B@:0
Recv: T:19.26 /0.00 B:20.90 /0.00 @:0 B@:0
Changing monitoring state from "Operational" to "Starting".
Send: N0 M110 N0125
Recv: ok
Changing monitoring state from "Starting" to "Printing
Send: N1 M140 S7083
Recv: ok
Send: N2 M10537
Recv: ok T:19.34 /0.00 B:20.86 /70.00 @:0 B@:0
Send: N3 M190 S70*92
Recv: T:19.34 /0.00 B:20.86 /70.00 @:0 B@:0 W:?
Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:3997
Please see OctoPrint randomly loses connection to the printer with a "SerialException" - FAQ - OctoPrint Community Forum for possible reasons of this.
Changing monitoring state from "Printing" to "Offline after error".
