Hy since i have installed the new version of Octoprint 1.3.8 on Octopi 0.14 i cannot start a Printjob anymore, after 20 to 25 sec octoprint tries to reconnect to the printer and i don't know why!
I used octoprint before also in version 1.3.8 but just had problems connecting via ssh - so i took a new image and setup octopi again.
I tried to play with the timeout settings on serial conection but with no sucess, always the reconnect in the interfeace but when i watch the terminal, ocotprint still gets data over serial.
I did not change anything on my setup except reinstall octoprint, i have the same firmware Marlin 1.1.8 and it's the same raspy and same connection cables.
I can start printing with a pc and simplify 3d with no problems.
What else do you need?
Kind regards
Manuel
serial.log:
2018-04-16 11:15:11,201 - Connecting to: /dev/ttyUSB0
2018-04-16 11:15:11,222 - Changing monitoring state from "Offline" to "Opening serial port"
2018-04-16 11:15:11,234 - Connected to: Serial<id=0x73a5d7b0, open=True>(port='/dev/ttyUSB0', baudrate=250000, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2018-04-16 11:15:11,236 - Changing monitoring state from "Opening serial port" to "Connecting"
2018-04-16 11:15:11,245 - Send: N0 M110 N0*125
2018-04-16 11:15:12,311 - Recv: start
2018-04-16 11:15:12,315 - Send: N0 M110 N0*125
2018-04-16 11:15:12,349 - Recv: echo: External Reset
2018-04-16 11:15:12,350 - Recv: Marlin bugfix-1.1.x
2018-04-16 11:15:12,351 - Recv:
2018-04-16 11:15:12,352 - Recv: echo: Last Updated: 2018-01-20 | Author: (none, default config)
2018-04-16 11:15:12,353 - Recv: echo:Compiled: Mar 20 2018
2018-04-16 11:15:12,354 - Recv: echo: Free Memory: 3933 PlannerBufferBytes: 1232
2018-04-16 11:15:12,359 - Recv: echo:V52 stored settings retrieved (671 bytes; crc 26505)
2018-04-16 11:15:12,360 - Recv: echo: G21 ; Units in mm
2018-04-16 11:15:12,361 - Recv: echo: M149 C ; Units in Celsius
2018-04-16 11:15:12,362 - Recv:
2018-04-16 11:15:12,362 - Recv: echo:Filament settings: Disabled
2018-04-16 11:15:12,363 - Recv: echo: M200 D1.75
2018-04-16 11:15:12,364 - Recv: echo: M200 D0
2018-04-16 11:15:12,378 - Recv: echo:Steps per unit:
2018-04-16 11:15:12,386 - Recv: echo: M92 X80.00 Y80.00 Z1600.00 E424.00
2018-04-16 11:15:12,388 - Recv: echo:Maximum feedrates (units/s):
2018-04-16 11:15:12,388 - Recv: echo: M203 X300.00 Y300.00 Z5.00 E40.00
2018-04-16 11:15:12,389 - Recv: echo:Maximum Acceleration (units/s2):
2018-04-16 11:15:12,390 - Recv: echo: M201 X3000 Y3000 Z100 E5000
2018-04-16 11:15:12,391 - Recv: echo:Acceleration (units/s2): P<print_accel> R<retract_accel> T<travel_accel>
2018-04-16 11:15:12,392 - Recv: echo: M204 P3000.00 R3000.00 T3000.00
2018-04-16 11:15:12,393 - Recv: echo:Advanced: S<min_feedrate> T<min_travel_feedrate> B<min_segment_time_us> X<max_xy_jerk> Z<max_z_jerk> E<max_e_jerk>
2018-04-16 11:15:12,394 - Recv: echo: M205 S0.00 T0.00 B20000 X10.00 Y10.00 Z0.30 E5.00
2018-04-16 11:15:12,395 - Recv: echo:Home offset:
2018-04-16 11:15:12,396 - Recv: echo: M206 X0.00 Y0.00 Z0.00
2018-04-16 11:15:12,397 - Recv: echo:Mesh Bed Leveling:
2018-04-16 11:15:12,398 - Recv: echo: M420 S0 Z0.00
2018-04-16 11:15:12,399 - Recv: echo: G29 S3 X1 Y1 Z-0.75000
2018-04-16 11:15:12,400 - Recv: echo: G29 S3 X2 Y1 Z-0.72500
2018-04-16 11:15:12,401 - Recv: echo: G29 S3 X3 Y1 Z-0.50000
2018-04-16 11:15:12,402 - Recv: echo: G29 S3 X4 Y1 Z-0.35000
2018-04-16 11:15:12,403 - Recv: echo: G29 S3 X5 Y1 Z-0.12500
2018-04-16 11:15:12,404 - Recv: echo: G29 S3 X1 Y2 Z-0.55000
2018-04-16 11:15:12,404 - Recv: echo: G29 S3 X2 Y2 Z-0.30000
2018-04-16 11:15:12,405 - Recv: echo: G29 S3 X3 Y2 Z-0.15000
2018-04-16 11:15:12,406 - Recv: echo: G29 S3 X4 Y2 Z-0.00000
2018-04-16 11:15:12,407 - Recv: echo: G29 S3 X5 Y2 Z0.20000
2018-04-16 11:15:12,408 - Recv: echo: G29 S3 X1 Y3 Z-0.17500
2018-04-16 11:15:12,409 - Recv: echo: G29 S3 X2 Y3 Z0.02500
2018-04-16 11:15:12,410 - Recv: echo: G29 S3 X3 Y3 Z0.17500
2018-04-16 11:15:12,411 - Recv: echo: G29 S3 X4 Y3 Z0.30000
2018-04-16 11:15:12,412 - Recv: echo: G29 S3 X5 Y3 Z0.42500
2018-04-16 11:15:12,413 - Recv: echo: G29 S3 X1 Y4 Z-0.10000
2018-04-16 11:15:12,414 - Recv: echo: G29 S3 X2 Y4 Z0.05000
2018-04-16 11:15:12,415 - Recv: echo: G29 S3 X3 Y4 Z0.30000
2018-04-16 11:15:12,415 - Recv: echo: G29 S3 X4 Y4 Z0.40000
2018-04-16 11:15:12,416 - Recv: echo: G29 S3 X5 Y4 Z0.45000
2018-04-16 11:15:12,417 - Recv: echo: G29 S3 X1 Y5 Z0.10000
2018-04-16 11:15:12,418 - Recv: echo: G29 S3 X2 Y5 Z0.20000
2018-04-16 11:15:12,419 - Recv: echo: G29 S3 X3 Y5 Z0.22500
2018-04-16 11:15:12,424 - Recv: echo: G29 S3 X4 Y5 Z0.32500
2018-04-16 11:15:12,425 - Recv: echo: G29 S3 X5 Y5 Z0.45000
2018-04-16 11:15:12,426 - Recv: echo:Material heatup parameters:
2018-04-16 11:15:12,427 - Recv: echo: M145 S0 H180 B70 F0
2018-04-16 11:15:12,428 - Recv: echo: M145 S1 H240 B110 F0
2018-04-16 11:15:12,429 - Recv: echo:PID settings:
2018-04-16 11:15:12,430 - Recv: echo: M301 P22.20 I1.08 D114.00
2018-04-16 11:15:12,431 - Recv: echo:Stepper driver current:
2018-04-16 11:15:12,432 - Recv: echo: M906 X 800 Y 800 Z 800 E0 800
2018-04-16 11:15:12,433 - Recv: echo:Sensorless homing threshold:
2018-04-16 11:15:12,434 - Recv: echo: M914 X15 Y40 Z8
2018-04-16 11:15:16,259 - Recv: ok
2018-04-16 11:15:16,282 - Changing monitoring state from "Connecting" to "Operational"
2018-04-16 11:15:16,285 - Send: N1 M105*38
2018-04-16 11:15:17,882 - Recv: ok T:15.49 /0.00 B:17.30 /0.00 @:0 B@:0
2018-04-16 11:15:17,889 - Send: N0 M110 N0*125
2018-04-16 11:15:17,906 - Recv: ok
2018-04-16 11:15:17,908 - Send: N1 M115*39
2018-04-16 11:15:17,944 - Recv: FIRMWARE_NAME:Marlin bugfix-1.1.x (Github) SOURCE_CODE_URL:https://github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Prusa i3 Pro B EXTRUDER_COUNT:1 UUID:cede2a2f-41a2-4748-9b12-c55c62f367ff
2018-04-16 11:15:17,948 - Recv: Cap:SERIAL_XON_XOFF:0
2018-04-16 11:15:17,949 - Recv: Cap:EEPROM:1
2018-04-16 11:15:17,950 - Recv: Cap:VOLUMETRIC:1
2018-04-16 11:15:17,952 - Recv: Cap:AUTOREPORT_TEMP:1
2018-04-16 11:15:17,955 - Recv: Cap:PROGRESS:0
2018-04-16 11:15:17,956 - Recv: Cap:PRINT_JOB:1
2018-04-16 11:15:17,957 - Recv: Cap:AUTOLEVEL:0
2018-04-16 11:15:17,959 - Recv: Cap:Z_PROBE:0
2018-04-16 11:15:17,960 - Recv: Cap:LEVELING_DATA:1
2018-04-16 11:15:17,961 - Recv: Cap:BUILD_PERCENT:0
2018-04-16 11:15:17,963 - Recv: Cap:SOFTWARE_POWER:1
2018-04-16 11:15:17,964 - Recv: Cap:TOGGLE_LIGHTS:0
2018-04-16 11:15:17,965 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2018-04-16 11:15:17,966 - Recv: Cap:EMERGENCY_PARSER:0
2018-04-16 11:15:17,967 - Recv: ok
2018-04-16 11:15:17,969 - Send: M21
2018-04-16 11:15:17,976 - Recv: ok
2018-04-16 11:15:17,978 - Send: M155 S2
2018-04-16 11:15:17,992 - Recv: ok
2018-04-16 11:15:19,989 - Recv: T:15.09 /0.00 B:17.27 /0.00 @:0 B@:0
2018-04-16 11:15:21,987 - Recv: T:16.87 /0.00 B:17.46 /0.00 @:0 B@:0
2018-04-16 11:15:24,001 - Recv: T:16.07 /0.00 B:18.55 /0.00 @:0 B@:0
2018-04-16 11:15:25,999 - Recv: T:14.69 /0.00 B:16.60 /0.00 @:0 B@:0
2018-04-16 11:15:28,004 - Recv: T:15.54 /0.00 B:16.68 /0.00 @:0 B@:0
2018-04-16 11:15:29,994 - Recv: T:15.04 /0.00 B:16.33 /0.00 @:0 B@:0
2018-04-16 11:15:31,990 - Recv: T:16.07 /0.00 B:17.54 /0.00 @:0 B@:0
2018-04-16 11:15:33,988 - Recv: T:16.52 /0.00 B:16.91 /0.00 @:0 B@:0
2018-04-16 11:15:35,985 - Recv: T:15.98 /0.00 B:17.70 /0.00 @:0 B@:0
2018-04-16 11:15:37,998 - Recv: T:16.43 /0.00 B:17.97 /0.00 @:0 B@:0
2018-04-16 11:15:39,996 - Recv: T:15.54 /0.00 B:17.07 /0.00 @:0 B@:0
2018-04-16 11:15:41,993 - Recv: T:16.96 /0.00 B:17.66 /0.00 @:0 B@:0
2018-04-16 11:15:43,992 - Recv: T:15.09 /0.00 B:17.50 /0.00 @:0 B@:0
2018-04-16 11:15:46,005 - Recv: T:16.29 /0.00 B:16.72 /0.00 @:0 B@:0
2018-04-16 11:15:48,001 - Recv: T:15.76 /0.00 B:16.45 /0.00 @:0 B@:0
2018-04-16 11:15:50,000 - Recv: T:16.87 /0.00 B:17.77 /0.00 @:0 B@:0
2018-04-16 11:15:51,998 - Recv: T:15.76 /0.00 B:16.87 /0.00 @:0 B@:0
2018-04-16 11:15:53,995 - Recv: T:16.38 /0.00 B:16.84 /0.00 @:0 B@:0
2018-04-16 11:15:56,008 - Recv: T:16.03 /0.00 B:17.70 /0.00 @:0 B@:0
2018-04-16 11:15:58,006 - Recv: T:15.98 /0.00 B:17.81 /0.00 @:0 B@:0
2018-04-16 11:16:00,003 - Recv: T:16.16 /0.00 B:17.07 /0.00 @:0 B@:0
2018-04-16 11:16:02,001 - Recv: T:16.61 /0.00 B:17.85 /0.00 @:0 B@:0
2018-04-16 11:16:03,998 - Recv: T:14.96 /0.00 B:17.58 /0.00 @:0 B@:0
2018-04-16 11:16:05,995 - Recv: T:15.04 /0.00 B:17.27 /0.00 @:0 B@:0
2018-04-16 11:16:08,009 - Recv: T:16.03 /0.00 B:16.64 /0.00 @:0 B@:0
2018-04-16 11:16:10,006 - Recv: T:16.65 /0.00 B:17.81 /0.00 @:0 B@:0
2018-04-16 11:16:12,003 - Recv: T:15.40 /0.00 B:16.87 /0.00 @:0 B@:0
2018-04-16 11:16:14,001 - Recv: T:16.43 /0.00 B:17.30 /0.00 @:0 B@:0
2018-04-16 11:16:15,998 - Recv: T:16.92 /0.00 B:17.50 /0.00 @:0 B@:0
2018-04-16 11:16:17,996 - Recv: T:15.80 /0.00 B:17.38 /0.00 @:0 B@:0
2018-04-16 11:16:19,993 - Recv: T:16.61 /0.00 B:17.15 /0.00 @:0 B@:0
2018-04-16 11:16:22,006 - Recv: T:16.29 /0.00 B:18.12 /0.00 @:0 B@:0
2018-04-16 11:16:24,003 - Recv: T:15.13 /0.00 B:17.27 /0.00 @:0 B@:0
2018-04-16 11:16:26,001 - Recv: T:14.78 /0.00 B:17.27 /0.00 @:0 B@:0
2018-04-16 11:16:27,998 - Recv: T:16.16 /0.00 B:16.76 /0.00 @:0 B@:0
2018-04-16 11:16:29,996 - Recv: T:16.29 /0.00 B:17.73 /0.00 @:0 B@:0
2018-04-16 11:16:31,994 - Recv: T:16.03 /0.00 B:16.87 /0.00 @:0 B@:0
2018-04-16 11:16:34,007 - Recv: T:16.47 /0.00 B:17.11 /0.00 @:0 B@:0
2018-04-16 11:16:36,004 - Recv: T:16.47 /0.00 B:17.70 /0.00 @:0 B@:0
2018-04-16 11:16:38,002 - Recv: T:15.31 /0.00 B:17.38 /0.00 @:0 B@:0
2018-04-16 11:16:39,999 - Recv: T:16.61 /0.00 B:17.03 /0.00 @:0 B@:0
2018-04-16 11:16:42,013 - Recv: T:16.34 /0.00 B:17.85 /0.00 @:0 B@:0
2018-04-16 11:16:44,010 - Recv: T:15.45 /0.00 B:16.87 /0.00 @:0 B@:0
2018-04-16 11:16:46,008 - Recv: T:15.27 /0.00 B:16.80 /0.00 @:0 B@:0
2018-04-16 11:16:48,005 - Recv: T:16.43 /0.00 B:17.50 /0.00 @:0 B@:0
2018-04-16 11:16:50,002 - Recv: T:15.18 /0.00 B:17.58 /0.00 @:0 B@:0
2018-04-16 11:16:52,015 - Recv: T:15.45 /0.00 B:16.60 /0.00 @:0 B@:0
2018-04-16 11:16:54,013 - Recv: T:16.43 /0.00 B:16.95 /0.00 @:0 B@:0
2018-04-16 11:16:56,010 - Recv: T:16.38 /0.00 B:17.42 /0.00 @:0 B@:0
2018-04-16 11:16:58,007 - Recv: T:15.63 /0.00 B:17.46 /0.00 @:0 B@:0
2018-04-16 11:17:00,005 - Recv: T:16.79 /0.00 B:16.99 /0.00 @:0 B@:0
2018-04-16 11:17:02,002 - Recv: T:15.94 /0.00 B:17.50 /0.00 @:0 B@:0
2018-04-16 11:17:04,000 - Recv: T:16.12 /0.00 B:17.70 /0.00 @:0 B@:0
2018-04-16 11:17:06,013 - Recv: T:15.04 /0.00 B:16.45 /0.00 @:0 B@:0
2018-04-16 11:17:08,010 - Recv: T:16.74 /0.00 B:17.77 /0.00 @:0 B@:0
2018-04-16 11:17:08,417 - Changing monitoring state from "Operational" to "Printing"
2018-04-16 11:17:08,455 - Send: N0 M110 N0*125
2018-04-16 11:17:08,458 - Recv: ok
2018-04-16 11:17:08,464 - Send: N1 M80 192.168.1.2*18
2018-04-16 11:17:08,746 - Unexpected error while reading serial port, please consult octoprint.log for details: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2417
2018-04-16 11:17:08,747 - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2018-04-16 11:17:08,754 - Changing monitoring state from "Printing" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2417)"
2018-04-16 11:17:08,760 - Connection closed, closing down monitor
