After upgrading Octopi to 1.7.2 I can no longer upload from SuperSlicer directly.
No matter what I've tried Octoprint is refusing the connection.
I ran the test from SuperSlicer to check the IP address and API Key. The test failed.
I looked at the API Key in the Octoprint UI and noticed that the Global API key was deprecated. I generated an application Key and tried that from SuperSlicer with the same result.
I then restarted Octoprint an tried again with the same result
haproxy.log (113.2 KB)
octoprint.log (70.3 KB)
plugin_pluginmanager_console.log (11.3 KB)
plugin_softwareupdate_console.log (161.5 KB)
plugin_softwareupdate_update.log (1.7 KB)
serial.log (28.3 KB)
Octoprint Version 1.7.2
Octopi Version 0.18.0, running on Raspberry Pi 3 Model B Rev 1.2
Safari running on MacOS 12.1 on Mac mini M1
