There was a timeout while trying to connect to the printer
Changed power supply for Raspberry pi
Changed USB cord
Researched issue online
Modified USB cable to not power board.
Turned printer and Pi on ant different intervals
Unplugged USB cam
serial.log
2020-05-19 17:53:51,297 - Connection closed, closing down monitor
2020-05-19 17:55:03,202 - Changing monitoring state from "Offline" to "Detecting serial port"
2020-05-19 17:55:03,323 - Serial port list: [u'/dev/ttyACM0']
2020-05-19 17:55:03,326 - Connecting to: /dev/ttyACM0
2020-05-19 17:55:03,339 - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-05-19 17:55:03,418 - Connected to: Serial<id=0x67709a10, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=30.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2020-05-19 17:55:03,425 - Changing monitoring state from "Opening serial port" to "Connecting"
2020-05-19 17:55:33,505 - There was a timeout while trying to connect to the printer
2020-05-19 17:55:33,527 - Changing monitoring state from "Connecting" to "Offline"
2020-05-19 17:55:33,556 - Connection closed, closing down monitor
octoprint.log
2020-05-19 17:55:03,203 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2020-05-19 17:55:03,340 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2020-05-19 17:55:03,475 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2020-05-19 17:55:33,538 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
dmesg
[ 12.678200] ieee80211 phy0: rt2x00lib_request_firmware: Info - Firmware detected - version: 0.36
[ 12.994736] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 13.336114] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 13.336677] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 14.201103] wlan0: authenticate with 48:5d:36:98:ad:12
[ 14.226250] wlan0: send auth to 48:5d:36:98:ad:12 (try 1/3)
[ 14.234058] wlan0: authenticated
[ 14.242491] wlan0: associate with 48:5d:36:98:ad:12 (try 1/3)
[ 14.246537] wlan0: RX AssocResp from 48:5d:36:98:ad:12 (capab=0x1031 status=0 aid=8)
[ 14.253047] wlan0: associated
[ 14.389854] cryptd: max_cpu_qlen set to 1000
[ 14.440300] wlan0: Limiting TX power to 30 (30 - 0) dBm as advertised by 48:5d:36:98:ad:12
[ 14.444203] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 179.368699] usb 1-1.4: USB disconnect, device number 4
[ 181.970157] usb 1-1.2: new full-speed USB device number 6 using dwc_otg
[ 182.103620] usb 1-1.2: New USB device found, idVendor=1eaf, idProduct=0004, bcdDevice= 2.00
[ 182.103641] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 182.103653] usb 1-1.2: Product: Maple
[ 182.103667] usb 1-1.2: Manufacturer: LeafLabs
[ 182.105271] cdc_acm 1-1.2:1.0: ttyACM0: USB ACM device
Ender 3 Pro
SKR Mini V1.2
Marlin Bugfix2.0.X
RasPi 3 B+
Version 1.4.0
