When I print, me octoprint stops. Makes nothing more and the printer keeps the heat, but doesnt move anymore. That can happen after some minutes, or after an hour. Very bad if the printer keeps the heat up forever ![]()
I have that since around the last 10 prints...
I tried to debug it and did many things...
In short I did:
- exchanges rapsi v3 with raspi v4 incl new SD card.
- newest octopi installed 1 week ago
- 5v in usb cable "isolated" to remove power to printer trough usb (Put tape on the 5V pin - Why and how)
- I did replace the USB cable completly
- switched from usb3 to usb2 at raspi v4
- tried a lot of conenction settings
- low latency: on, off
- parity double check : Always, never
- exclusive access: yes, no
I cant figure out the issue.
I did enable serial logging, and there are some things strange:
2024-02-15 13:19:48,201 - Enabling serial logging
2024-02-26 15:16:16,966 - Changing monitoring state from "Offline" to "Detecting serial connection"
2024-02-26 15:16:17,782 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2024-02-26 15:16:17,782 - Trying port /dev/ttyUSB0, baudrate 115200
2024-02-26 15:16:17,945 - Connecting to port /dev/ttyUSB0, baudrate 115200
2024-02-26 15:16:18,084 - Handshake attempt #1 with timeout 2.0s
2024-02-26 15:16:18,270 - Connected to: Serial<id=0xacb7bd48, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2024-02-26 15:16:18,272 - Send: N0 M110 N0125
2024-02-26 15:16:20,274 - Handshake attempt #2 with timeout 2.0s
2024-02-26 15:16:20,379 - Send: N0 M110 N0125
2024-02-26 15:16:22,394 - Handshake attempt #3 with timeout 2.0s
2024-02-26 15:16:22,429 - Send: N0 M110 N0125
2024-02-26 15:16:24,404 - Trying port /dev/ttyUSB0, baudrate 250000
2024-02-26 15:16:24,434 - Handshake attempt #1 with timeout 2.0s
2024-02-26 15:16:24,475 - Send: N0 M110 N0125
2024-02-26 15:16:26,478 - Handshake attempt #2 with timeout 2.0s
2024-02-26 15:16:26,484 - Send: N0 M110 N0125
2024-02-26 15:16:28,486 - Handshake attempt #3 with timeout 2.0s
2024-02-26 15:16:28,535 - Send: N0 M110 N0125
2024-02-26 15:16:30,532 - Trying port /dev/ttyUSB0, baudrate 230400
2024-02-26 15:16:30,535 - Handshake attempt #1 with timeout 2.0s
2024-02-26 15:16:30,541 - Send: N0 M110 N0125
2024-02-26 15:16:32,543 - Handshake attempt #2 with timeout 2.0s
2024-02-26 15:16:32,553 - Send: N0 M110 N0125
2024-02-26 15:16:58,388 - Closing down send loop
2024-02-26 15:16:58,389 - Changing monitoring state from "Detecting serial connection" to "Offline"
2024-02-26 15:17:09,445 - Changing monitoring state from "Offline" to "Detecting serial connection"
2024-02-26 15:17:09,463 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2024-02-26 15:17:09,464 - Trying port /dev/ttyUSB0, baudrate 115200
2024-02-26 15:17:09,466 - Connecting to port /dev/ttyUSB0, baudrate 115200
2024-02-26 15:17:09,558 - Handshake attempt #1 with timeout 2.0s
2024-02-26 15:17:09,571 - Connected to: Serial<id=0xacb7b910, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2024-02-26 15:17:09,573 - Send: N0 M110 N0*125
2024-02-26 15:17:10,594 - Recv: start
2024-02-26 15:17:10,598 - Changing monitoring state from "Detecting serial connection" to "Operational"
As you can see, sometimes it doesnt connect, I need to press manually cacle to disconnect and reconnect. Sometimes it did work directly. Did enable the wait on start, that did fix it, it seams...
But the printing issue is still there:
2024-02-26 15:52:08,079 - Send: N25226 G1 F1950 X106.715 Y39.23 E791.861351
2024-02-26 15:52:08,109 - Recv: ok
2024-02-26 15:52:08,111 - Send: N25227 G0 F9750 X107.103 Y39.409118
2024-02-26 15:52:08,269 - Recv: ok
2024-02-26 15:52:08,271 - Send: N25228 G1 F1950 X108.847 Y37.664 E791.9434148
2024-02-26 15:52:08,317 - Recv: ok
2024-02-26 15:52:08,319 - Send: N25229 G0 F9750 X109.13 Y37.94779
2024-02-26 15:52:08,445 - Recv: ok
2024-02-26 15:52:08,451 - Send: N25230 G1 F1950 X107.448 Y39.629 E792.0225261
2024-02-26 15:52:08,509 - Recv: ok
2024-02-26 15:52:08,511 - Send: N25231 G0 F9750 X107.757 Y39.886125
2024-02-26 15:52:08,637 - Recv: ok
2024-02-26 15:52:08,639 - Send: N25232 G1 F1950 X109.413 Y38.23 E792.100422
2024-02-26 15:52:08,669 - Recv: ok
2024-02-26 15:52:08,670 - Send: N25233 G0 F9750 X109.696 Y38.513125
2024-02-26 15:57:08,695 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2024-02-26 15:57:08,702 - Send: N25234 M105*37
2024-02-26 15:57:43,354 - Changing monitoring state from "Printing" to "Cancelling"
2024-02-26 15:57:48,165 - Connection closed, closing down monitor
2024-02-26 15:57:57,691 - Changing monitoring state from "Cancelling" to "Offline"
another try:
2024-02-26 16:31:41,719 - Send: N20525 M10539
2024-02-26 16:31:41,727 - Recv: ok T:236.1 /235.0 B:69.7 /70.0 T0:236.1 /235.0 @:39 B@:127
2024-02-26 16:31:41,733 - Send: N20526 G1 X46.363 Y116.183 E631.4162589
2024-02-26 16:31:41,765 - Recv: ok
2024-02-26 16:31:41,767 - Send: N20527 G1 X47.7 Y115.382 E631.4680995
2024-02-26 16:31:41,813 - Recv: ok
2024-02-26 16:31:41,815 - Send: N20528 G1 X49.1 Y114.72 E631.519693
2024-02-26 16:31:41,860 - Recv: ok
2024-02-26 16:31:41,863 - Send: N20529 G1 X50.551 Y114.201 E631.5708586
2024-02-26 16:31:41,909 - Recv: ok
2024-02-26 16:31:41,911 - Send: N20530 G1 X52.061 Y113.823 E631.6226290
2024-02-26 16:31:41,956 - Recv: ok
2024-02-26 16:31:41,958 - Send: N20531 G1 X53.593 Y113.596 E631.6741384
2024-02-26 16:31:42,004 - Recv: ok
2024-02-26 16:31:42,006 - Send: N20532 G1 X55.143 Y113.519 E631.7257590
2024-02-26 15:36:42,035 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
I can upload files to the SD Cart of the printer via octoprint. Did it with 7MB. no connection issues over 22 Minutes and no resend.
repeated 8 times. Nearly 3 hours completly uploading, deleting, uploading again. No issue at all with the connection to the printer.
I did yesterday a print directly on the printer, without octoprint. Worked fine.
Then today tried again the same job via octoprint to generate the serial.log.
The printer is running fine. Uload and the connection it seams too.
What is working with the octoprint?
I did a backup of my settings and plugins.
The only plugin I cant disable is the PSU control, as that thing is controlling the power to the printer.
Smart preheat is working fine. Dont think thats an issue.
Any settings completly wrong?
