Hi all,
I had the issue yesterday for the first time, during the print the connection with the printer was lost after a few hours. If I remember correctly, the message was "TMC Connection Time Out". After this I've started a new print that ran later that evening, without any issues.
So after that I've started a new print, around 10:00 in the evening, and I've checked the print a few times today (using my VPN). But now I see the printer has stopped, so I think the error occurred.
The only thing I can think of is that I've installed a plugin showing the % in the browser navigation bar. So I've deleted this plugin.
But when I am checking the logs, I see a lot of warnings and at 13:29 there is the follow message in the log:
2020-02-03 13:59:28,945 - octoprint.plugins.DisplayLayerProgress - INFO - Printing stopped. Detailed progress stopped.
2020-02-03 13:59:28,956 - octoprint.plugins.excluderegion - INFO - Printing stopped: event=PrintFailed
What can / should I do to solve this? It was a 18hour print, that stopped at about 15 hours. So I feel kind of sad
This is a part of the log, around the mentioned time stamp:
2020-02-03 13:52:15,445 - tornado.access - WARNING - 403 GET /sockjs/websocket (::ffff:10.8.0.2) 1.47ms
2020-02-03 13:53:36,157 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-02-03 13:53:36,395 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 101724}
2020-02-03 13:53:42,846 - backoff - INFO - Backing off get_dev_settings(...) for 35.0s (HTTPError: 401 Client Error: Unauthorized for url: http://newstream.getanywhere.io/api/dev_settings)
2020-02-03 13:54:18,217 - backoff - INFO - Backing off get_dev_settings(...) for 55.5s (HTTPError: 401 Client Error: Unauthorized for url: http://newstream.getanywhere.io/api/dev_settings)
2020-02-03 13:55:14,067 - backoff - INFO - Backing off get_dev_settings(...) for 56.3s (HTTPError: 401 Client Error: Unauthorized for url: http://newstream.getanywhere.io/api/dev_settings)
2020-02-03 13:56:10,723 - backoff - INFO - Backing off get_dev_settings(...) for 101.2s (HTTPError: 401 Client Error: Unauthorized for url: http://newstream.getanywhere.io/api/dev_settings)
2020-02-03 13:57:52,345 - backoff - INFO - Backing off get_dev_settings(...) for 76.8s (HTTPError: 401 Client Error: Unauthorized for url: http://newstream.getanywhere.io/api/dev_settings)
2020-02-03 13:59:09,584 - backoff - INFO - Backing off get_dev_settings(...) for 31.4s (HTTPError: 401 Client Error: Unauthorized for url: http://newstream.getanywhere.io/api/dev_settings)
2020-02-03 13:59:28,614 - octoprint.util.comm - ERROR - Unexpected error while reading from serial port
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 2793, in _readline
ret = self._serial.readline()
File "/home/pi/oprint/local/lib/python2.7/site-packages/octoprint/util/comm.py", line 4932, in readline
c = self.read(1)
File "/home/pi/oprint/local/lib/python2.7/site-packages/serial/serialposix.py", line 501, in read
'device reports readiness to read but returned no data '
SerialException: device reports readiness to read but returned no data (device disconnected or multiple access on port?)
2020-02-03 13:59:28,644 - octoprint.util.comm - ERROR - Please see https://faq.octoprint.org/serialerror for possible reasons of this.
2020-02-03 13:59:28,660 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline (Error: SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793)"
2020-02-03 13:59:28,729 - octoprint.plugins.filamentmanager - INFO - Filament used: 69043.9356 mm (tool0)
2020-02-03 13:59:29,175 - octoprint.plugins.tracking - INFO - Sent tracking event print_failed, payload: {'origin': 'local', 'reason': 'error', 'commerror_text': "SerialException: 'device reports readiness to read but returned no data (device disconnected or multiple access on port?)' @ comm.py:_readline:2793", 'file': '26a6568620b0733510cf9141f3e0f1e95f0e3db5', 'elapsed': 58543}
