OctoPrint has been working successfully with my Prusa I3 MK3S for several months. A few days ago OctoPrint stopped connecting to the MKS. It gets stalled at "opening serial connection".
I recreated a system image from Octopi_buster_lite_0.17.0.
The system worked successfully. Since I had previously updated the s/w to 1.4.2 and was using it successfully I updated again to 1.4.2
The problem reappeared.
I have no plugins except those tha are bundled with the update.
After starting up in safe mode the serial connection to the printer is made successfully.
After rebooting in normal mode the problem reappears
Complete Logs
I don't know how to get the serial.log off the Rpi but it looks like the following screen grab from by browser:
Performing autodetection with 7 port/baudrate candidates: /dev/ttyACM0@115200, /dev/ttyACM0@250000, /dev/ttyACM0@230400, /dev/ttyACM0@57600, /dev/ttyACM0@38400, /dev/ttyACM0@19200, /dev/ttyACM0@9600
Trying port /dev/ttyACM0, baudrate 115200
Connecting to port /dev/ttyACM0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0xae9d5a70, open=True>(port='/dev/ttyACM0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Handshake attempt #2 with timeout 2.0s
Send: N0 M110 N0125
Handshake attempt #3 with timeout 2.0s
Send: N0 M110 N0125
Trying port /dev/ttyACM0, baudrate 250000
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Trying port /dev/ttyACM0, baudrate 230400
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Trying port /dev/ttyACM0, baudrate 57600
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Trying port /dev/ttyACM0, baudrate 38400
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Trying port /dev/ttyACM0, baudrate 19200
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Trying port /dev/ttyACM0, baudrate 9600
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0*125
Changing monitoring state from "Detecting serial connection" to "Error: No more candidates to test, and no working port/baudrate combination detected."
Changing monitoring state from "Error: No more candidates to test, and no working port/baudrate combination detected." to "Offline (Error: No more candidates to test, and no working port/baudrate combination detected.)"
Here is a log:
2020-09-26 terminal 1-05.txt.zip (1.3 KB)
Running OctoPrint (version 1.4.2 is causing the problem) with no plugins except for what is bundled with 1.4.2
Raspberry pi 4B
Prusa I3 MKS
accessing octoprint.local from Firefox browser on MacBook
