The printer (Sunlu S8) while printing via USB freezes for a second or 2 and then continues.
- Updated TH3D firmware from 2.24 to 2.31
- Updated Octoprint from 1.5.2. to 1.6.1.
- Changed 4 usb cables (although none with ferite core, but performances were the same)
- A suspect firmware of the board.... but no clue what to fix, as I freshly flashed the printer.
Yes
browser.user_agent : Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/91.0.4472.164 Safari/537.36
connectivity.connection_check : 1.1.1.1:53
connectivity.connection_ok : true
connectivity.enabled : true
connectivity.online : true
connectivity.resolution_check : octoprint.org
connectivity.resolution_ok : true
env.hardware.cores : 4
env.hardware.freq : 1500
env.hardware.ram : 3959984128
env.os.bits : 32
env.os.id : linux
env.os.platform : linux
env.plugins.pi_support.model : Raspberry Pi 4 Model B Rev 1.2
env.plugins.pi_support.octopi_version : 0.18.0
env.plugins.pi_support.throttle_state : 0x0
env.python.pip : 20.3.3
env.python.version : 3.7.3
env.python.virtualenv : true
octoprint.safe_mode : true
octoprint.version : 1.6.1
printer.firmware : Marlin TH3D UFW 2.31 (Jul 26 2021 19:07:12)
systeminfo.generator : systemapi
OctoPrint version: 1.6.1
OctoPi version: 0.18.0
Printer: Sunlu S8, original board, added BLtouch
Board with OctoPi: Raspberry Pi 4
Firmware: TH3D 2.31
Browser: Chrome
Operating system: Windows 10
Points in serial.log where the problem happened:
2021-07-26 18:45:17,291 - Send: N9324 G1 F4800 X167.802 Y150.832 E152.33057*55
2021-07-26 18:45:17,575 - Recv: ok
**2021-07-26 18:45:17,577 - Send: N9325 G0 F12000 X168.257 Y150.721*79**
**2021-07-26 18:45:19,258 - Recv: o-á T:240.00 /240.00 B:80.00 /80.00 @:61 B@:0**
2021-07-26 18:45:21,258 - Recv: T:240.00 /240.00 B:79.86 /80.00 @:63 B@:127
2021-07-26 18:45:21,259 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-07-26 18:45:21,273 - Send: N9326 M105*25
2021-07-26 18:45:21,285 - Recv: ok T:240.00 /240.00 B:79.86 /80.00 @:63 B@:127
2021-07-26 18:45:21,291 - Send: N9327 G1 F4800 X171.511 Y153.975 E152.48362*52
2021-07-26 18:45:21,301 - Recv: ok
2021-07-26 18:45:52,714 - Send: N10313 G1 X174.813 Y149.705 E165.25938*99
2021-07-26 18:45:52,722 - Recv: ok
**2021-07-26 18:45:52,722 - Send: N10314 G1 X174.813 Y149.716 E165.25975*111**
**2021-07-26 18:45:53,274 - Recv: o-á T:239.81 /24r‚‚þ B:79.82 /80.00 @:69 B@:127**
2021-07-26 18:45:55,274 - Recv: T:239.94 /240.00 B:79.76 /80.00 @:66 B@:127
2021-07-26 18:45:57,279 - Recv: T:239.94 /240.00 B:79.76 /80.00 @:66 B@:127
2021-07-26 18:45:57,279 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-07-26 18:45:57,292 - Send: N10315 M105*33
2021-07-26 18:45:57,316 - Recv: ok T:239.94 /240.00 B:79.83 /80.00 @:66 B@:127
2021-07-26 18:45:57,323 - Send: N10316 G1 X174.83 Y150.014 E165.26967*81
2021-07-26 18:45:57,332 - Recv: ok
2021-07-26 18:46:02,146 - Recv: ok
2021-07-26 18:46:02,147 - Send: N10617 G1 X140.68 Y143.388 E168.8414*107
**2021-07-26 18:46:03,279 - Recv: o-á T:239.88 /240.00 B:80.07 /80.00 @:68 B@:0**
**2021-07-26 18:46:05,279 - Recv: T:239.88 /240.00 B:80.12 /80.00 @:68 B@:0**
2021-07-26 18:46:05,280 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2021-07-26 18:46:05,292 - Send: N10618 M105*41
2021-07-26 18:46:05,305 - Recv: ok T:239.88 /240.00 B:80.12 /80.00 @:68 B@:0
2021-07-26 18:46:05,312 - Send: N10619 G1 X140.828 Y143.611 E168.8503*91
2021-07-26 18:46:05,321 - Recv: ok
Octoprint.log
CCR10S_SmartTemperatureTower_PETG_220-265.gcode, owner: logocar3, user: logocar3
2021-07-26 18:34:33,791 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2021-07-26 18:34:33,799 - octoprint.util.comm - INFO - Changing monitoring state from "Starting" to "Printing"
2021-07-26 18:40:45,207 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-07-26 18:41:07,208 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-07-26 18:41:21,412 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2021-07-26 18:43:01,229 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-07-26 18:44:27,250 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-07-26 18:44:35,256 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-07-26 18:44:45,255 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-07-26 18:45:21,258 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-07-26 18:45:57,279 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2021-07-26 18:46:05,280 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
Thank you for your help!
